QUOTE(RobW @ Nov 22 2011, 07:18 AM)
Or you could tell us....
OK OK...
On a scale of 1 to 10, a stripped down 914 with a 4 cylinder torque motor is anyone's Easy 9. It's becomes a 10 when the driver can manage to put together a great run and capture a podium spot for the day.
My car, now being about 90%+ sorted, is very neutral. It doesn't misbehave at all. On the other hand the driver can easily lose time on a course by over cooking corners, performing brain fade things like hitting the loud pedal on 180's before the car is fully rotated and so on and so on..... In fact the real challenge is driving 10 tenths and doing it mistake free. This latter challenge is very difficult to do.
Also I'm still exploring the limits of the car and will start this all over again next year when I go with a different tire setup. Running on some new sticky tires will be a whole new experience, abet expensive.
What you also find is that the faster you go the more time you have to put in to bring the last thing, or system that failed, or that isn't working correctly, up to par.
But when all systems are go and the tires get hot, say like at the Medford WCR, it becomes an attack machine. You can simply attack most corners. Hard to believe but true and just a whole bunch of fun.
Of course there will always be some corners that you have to sneak up on, i.e., like 10 at Infineon or the big (first corner) sweeper at Medford.
