Chevy Guys, Starter sticking |
rascobo |
Apr 2 2011, 10:45 PM
Member Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/WTF.gif) In the last six months I replaced the ring and bendix gears four times, in addition to exploding one trans-axle and shattering one clutch disc (bump starting the car) I'd like to resolve this rather than just continuing to throwing all my time and money at it.
I've been using an IMI 101 gear reduction starter with my 4.3 V6 conversion for several years with no problems, but because of alignment problems with the Kennedy adapter plate I've had to replace both the starter Bendix gear and flywheel ring gear several times. I also had intermittent problems with the starter failing to disengage. I think I solved the alignment issue and just installed new ring and Bendix gears, but they are still sticking(failing to disengage). I have searched the problem on-line, lots of results, mostly contradictory or confusing, regarding shimming. It's not possible to see or test the clearances like in a chevy engine to chevy bell housing. Can someone tell Me how (if possible) to correct this problem with shims? Or does it seem more likely the problem has developed in the starter Bendix drive? (IMG:style_emoticons/default/idea.gif) |
Mike Bellis |
Apr 2 2011, 10:48 PM
My kit used a Kennedy flywheel and a 911 starter. Never had the starter hang up on my V8.
Bruce Hinds |
Apr 3 2011, 09:46 AM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I'm not familiar with the IMI 101 starter, is that a VW/POR unit?
I used my stock 914 starter on a v8 for years and never understood the fuss, compression would hole it up occaisionally, but kick it again and it would go. what I didn't realize until after I ruined the ring gear on the starter was that the vw/por starters don't have a larger enough bearing which will allow some end play in the shaft and they as it wears, starts eating teeth. After replacing my ring gear, I popped for the reverse rotation chevy unit from kennedy. that's the ticket. |
Lo-Fi Version | Time is now: 14th May 2024 - 06:35 PM |
