Looking for a low buck solution for a fuel pump for a 2.0 F.I. car |
rick 918-S |
Apr 6 2011, 09:02 PM
Hey nice rack! -Celette Group: Members Posts: 20,463 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I saw a post where someone bought a NOS type IV pump and paid several hundred bucks for it. Ya, with all the cars I'm building here I'm not that guy.
What type of fuel pump are you running? What type of pressure does our system F.I. run at? |
jaxdream |
Apr 6 2011, 09:16 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Don't quote me on it , I believe the 2.0l d jet runs around 28-30psi. I think the later FI changed from the 3 port to a 2 port doing away with running the return through the fuel pump . I'm with ya on the high dollar FI parts , heck I bet Holley makes a pump that would be able to supply the d jet . Check out Jeff Bolwsby's ( spelling may be wrong ) site , tons of info about d jet , maybe the psi and flow specs might be there .Good luck , buy a lotto ticket.
Jack / Jaxdream |
rick 918-S |
Apr 6 2011, 09:38 PM
Don't quote me on it , I believe the 2.0l d jet runs around 28-30psi. I think the later FI changed from the 3 port to a 2 port doing away with running the return through the fuel pump . I'm with ya on the high dollar FI parts , heck I bet Holley makes a pump that would be able to supply the d jet . Check out Jeff Bolwsby's ( spelling may be wrong ) site , tons of info about d jet , maybe the psi and flow specs might be there .Good luck , buy a lotto ticket. Jack / Jaxdream Thanks, Ya I'll check Jeffs stuff. We bought a ticket the wife is checking now. (IMG:style_emoticons/default/unsure.gif) |
hasaramat |
Apr 6 2011, 09:45 PM
Member Group: Members Posts: 80 Joined: 23-November 08 From: Utah Member No.: 9,782 Region Association: None |
I have used the MSD high pressure pump in several different applications for EFI and it has been great. Right around $100 and it come with mounts. Great flow rate and not bad power consumption and good to 70 psi.
SLITS |
Apr 6 2011, 10:14 PM
I bought both a 911 CIS pump and a late model teener pump off eBay for about $60 each, new, Chinese or ?. Someday I'll let you know if they work.
rick 918-S |
Apr 6 2011, 10:15 PM
I have used the MSD high pressure pump in several different applications for EFI and it has been great. Right around $100 and it come with mounts. Great flow rate and not bad power consumption and good to 70 psi. Just spotted one on Ebay for $ 100.00. I thought it may work since our system has a regulator. |
Cap'n Krusty |
Apr 6 2011, 10:52 PM
Not a particularly good idea to try to regulate a 100 PSI pump down to 30 PSI. We call 'em fires waiting to happen ........ and they don't wait very long.
The Cap'n |
rick 918-S |
Apr 6 2011, 11:02 PM
Not a particularly good idea to try to regulate a 100 PSI pump down to 30 PSI. We call 'em fires waiting to happen ........ and they don't wait very long. The Cap'n Eeek! (IMG:style_emoticons/default/unsure.gif) |
JRust |
Apr 6 2011, 11:04 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
There has to be something out there that will work. I went through like 7 bad pumps to find a good used one recently. Talk about a PITA (IMG:style_emoticons/default/mad.gif) . It would be nice if they could rebuild them & be reliable. Not to mention the biggest obstacle (we are all cheap (IMG:style_emoticons/default/blink.gif) )
avidfanjpl |
Apr 6 2011, 11:31 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
The 3 port original pump runs at 29-30 PSI published, and measured at the Drivers side rail outlet going to the 5th injector for ease of access, but I run mine at 31.
I have 2, one in the car that was new in 2006, Bosch, PO paid 250, then I bought a real Bosch spare from Jeff Bowlsby. Tested it and it works fine. 90 bucks from Jeff. THE Problem is that there are a ton of CRAPPY Chinese knockoffs on the market and they are NOT Bosch. They work for a bit then die. Many have been fooled into buying them. You can see they always refer to the correct Bosch number, but they are not NOS. They are NCS - New Crap Stock. You will not like spending 250 and getting crap. The only thing usable if you are sticking with the 3 port pump is Bosch. Sad but true. And the crappy rebuild kits for Bosch are also almost all from China as well. And from what I hear, even the Bosch rebuild kits are horrible to try and do the work correctly and not have them leak. Let the buyer beware. John |
76-914 |
Apr 7 2011, 09:00 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Rick, a while back someone here posted that you could use a Delco. Supposedly, there is a chart (Delco) that lists each pumps operating psi range and flow rate. Just match up your requirements. I chickened out and bought a Bosch from Pelican.
Apr 7 2011, 09:32 AM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
That was me.
Rick, its simple... Go to the parts store. Get out the big paper fuel pump book. Look up the 75/76 914 fuel pump. Look at two specs. PSI/GPH and the fittings sizes. Then cross reference that. Easier is to look up the Volvo P1800 ES 1973 Same pump, way lower price. Mounts up front under the tank like the 75/76 pump and its a whole lot cheaper than any 914 three orifice pump. If you insist on a three port pump, you are stuck with a 914 pump only. If you go with the two port pump (mounted up front) your choices open up alot. BMW is one of the pumps also... So there are alot of choices... The original was 65 PSI. I just matched the specs and found the Delco for 100 bucks. Works great, no issues. I would suggest that you consider replacing the tunnel lines...I did mine with copper tubing (flame on) and its fine and has been for 12 years so far. I figure if my furnace can use copper, so can my car. I dont drive 15k mile per year in my car ....and I am cheap. I also can smell gas...so I wont ignore it if and when the copper needs to be replaced. I also found a nice pre-wrapped two wire deal at Home Depot. I plugged it into the fuel pump wiring at the stock location and ran it up the tunnel and out the front under the tank. Never touched the main harness...no need to. Rich |
rick 918-S |
Apr 7 2011, 01:05 PM
Great info from everyone. I have since received a pm with an offer for a pump so it looks like I'm set. Thanks everyone!
76-914 |
Apr 7 2011, 04:00 PM
That's right. It was you, Rich. Suddenly my memory awakes. But why 2 wires to the pump? (IMG:style_emoticons/default/poke.gif) A true CSOB would run a single wire.
jmill |
Apr 7 2011, 04:06 PM
I thought I included the pump with the engine? If I didn't, I should have one or two I could give you.
PM me before you go and buy stuff. Chances are good I might have it. |
Apr 7 2011, 04:09 PM
That's right. It was you, Rich. Suddenly my memory awakes. But why 2 wires to the pump? (IMG:style_emoticons/default/poke.gif) A true CSOB would run a single wire. true true. It must have been a good week that week when I went to home depot. it was like 12 years ago...something like that. Rich |
Krieger |
Apr 7 2011, 06:53 PM
Advanced Member Group: Members Posts: 4,714 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Last night I was looking in the members vender section hwgunner/gpr(midenginemania.com). If I remember right he a new fuel pump for 75-6 car for $180.
rick 918-S |
Apr 7 2011, 07:29 PM
That sounds like a good price for a new stock pump. I have my pump problem resolved thanks to the guys on World! (IMG:style_emoticons/default/smilie_pokal.gif)
McMark |
Apr 7 2011, 07:46 PM
Just looked at the factory manuals and found these specs for the pump:
Pressure: 2.4 kp/cm^2 Flow: 50 ltr/h This translates to: Pressure: 34 psi Flow: 13.2 gal/h I looked on SummitRacing.com and found this pump which would probably work. But I don't have any first-hand experience with it, so I'm not recommending it, just suggesting it. (IMG:style_emoticons/default/wink.gif) Pressure: 40psi Flow: 43 gal/h MSD-2225 (IMG:http://www.914world.com/bbs2/uploads_offsite/static.summitracing.com-419-1302227271.1.jpg) |
markb |
Apr 7 2011, 09:11 PM
Last night I was looking in the members vender section hwgunner/gpr(midenginemania.com). If I remember right he a new fuel pump for 75-6 car for $180. If you start calling us first, you could probably start saving some $$$$ (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 11:45 PM |
