Clear Bra |
Clear Bra |
7391420 |
May 6 2004, 01:10 PM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
Its the same stuff that all the high end car dealers offer at their shops as a service. For pricey cars, people pay 500-900.00 to have it done. there are a bunch of specialty shops all over that basically have a computer set up with a printer that prints and cuts out sets of this film for each specific car. it's a pretty good idea, I'm told that after 7+ years or so the film will yellow, but all you can remove it by heating the surface, hot water and then peel.
Ferg |
May 10 2004, 02:52 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I know some of you wanted pic's of how it looks on the car. Well I took 10 shots last night and you could not make out the edges in any of the pic's. That gives you an idea of the "clearness". Anyhow I will try again in better light, but it still may not turn out. Those of you at the WCC will get to see it first hand.
Ferg. |
ben*james |
Sep 12 2013, 09:27 PM
LIFER Group: Members Posts: 524 Joined: 16-February 09 From: Portland Oregon Member No.: 10,062 Region Association: Pacific Northwest |
It's holding up rather well, I thought it had very recently been installed. Yellowing a bit, but you can't even notice the bra until you are close to the car. (IMG:style_emoticons/default/sunglasses.gif)
carr914 |
Sep 13 2013, 05:38 AM
Racer from Birth Group: Members Posts: 118,899 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I'm told that after 7+ years or so the film will yellow, but all you can remove it by heating the surface, hot water and then peel. I've seen them yellow & develope cracks (looks kinda like a shattered window). I saw one car that needed to be painted as the Film had chemically bonded the paint and when they tried to remove it, the Paint came with it - this was on a "Paint to Sample" 911 |
rhodyguy |
Sep 13 2013, 08:37 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the cruiser came with a package installed. bad idea on a white or light car to me. it collected dirt/road grime that left a dark line on every edge and was impossible to clean. then it started to haze and lift on the edges. i had it removed. your results may vary.
k |
ben*james |
Sep 13 2013, 08:38 AM
I guess I'll report only slight yellowing out of that list. I'll take a picture when I get back to it and post. It's really quite impressive for such a time. (IMG:style_emoticons/default/sunglasses.gif)
bandjoey |
Sep 13 2013, 11:49 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
3M is selling this in a spray can now. Anyone try that ?
rhodyguy |
Sep 13 2013, 11:58 AM
how would you remove the spray on? hair dryer/heat gun was required to remove the sheet style. prob a better app for darker cars.
k |
URY914 |
Sep 13 2013, 12:42 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Here's a see thru bra. Don't know how well it would on the front of a 914..........
rhodyguy |
Sep 13 2013, 12:53 PM
that would be period correct for 73s and 74s.
Lo-Fi Version | Time is now: 1st June 2024 - 08:11 AM |
