| 914World |
Mar 1 2011, 01:49 PM
Member #1 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None
I have the complete driver's side (left) inner and outer rear suspension console assembly. Also the outer triangular swing arm mount console is attached as well. These 2 pieces are the complete inner and outer mounts for the rear suspension swing arm. Both cut a few inches beyond the factory seams for more metal to grind and work with. Both good an solid only light surface rust in a few small areas. Please note this is the driver's side. I don't have the passenger side. $225. Thanks Bill (704)829-0976
Lo-Fi Version | Time is now: 21st September 2026 - 05:16 PM |
