I have the complete driver's side (left) inner and outer rear suspension console assembly. Also the outer triangular swing arm mount console is attached as well. These 2 pieces are the complete inner and outer mounts for the rear suspension swing arm. Both cut a few inches beyond the factory seams for more metal to grind and work with. Both good an solid only light surface rust in a few small areas. Please note this is the driver's side. I don't have the passenger side. $225. Thanks Bill (704)829-0976
- it's NOT ok to contact this poster with services or other commercial interests
View the full article
