Is anybody running one of these? |
jjackson |
Apr 8 2011, 09:09 PM
Member Group: Members Posts: 219 Joined: 5-October 10 From: maumelle, arkansas Member No.: 12,246 Region Association: None |
Bought a Quaiffe steering rack gear that quickens steering compared to stock.Has anybody installed one?If so, where did you get replacement seals or how did you remove old ones without damage.The part matches the pinion gear and has fewer teeth.This ia not a steering quickener that is added on shafts-never driven a car with these type units that had proper feel or feedback through the steering wheel.Have never driven a teener with either type.The capability of our car with its current setup, is CRAZY fast through slaloms and offsets.JJackson
jjackson |
Apr 9 2011, 09:58 AM
Help! Who rebuilt your steering rack? This replacement part makes the rack 2.5 turns lock to lock with absolutely minimum increase in steering resistance.Anyboby?JJackson
SLITS |
Apr 9 2011, 10:09 AM
I have never heard of the product, but I thought you would like at least one post answer.
All the rebuilders we sell to just remanufacture the stock rack. |
pcar916 |
Apr 9 2011, 10:23 AM
Hi J,
Take a look at this exploded drawing. http://www.pelicanparts.com/914/Parts/Fron...ng_rack_big.htm The parts at the end of the rack, especially the "Bearing/Bushing" must have a seal built into it. If the Quaife rack has the same dimensions (od) it'll work like the original. They may be pressed in. I haven't replaced one. If it were me I'd build up another rack from a donor car. Maybe Henry C. or the guys at PP have one, or get one from Rich Bontempi at High Performance House in Redwood City CA. That way you can just swap racks after removing the old one. Call me if you have questions. Ron |
jjackson |
Apr 9 2011, 12:37 PM
Ron,Thanks for the exploded picture.Looking for source on #7,#14,19, and 20 before we destroy donor rack-we have several donors-just wanted to find source for parts.Saw a recent post selling rebuilt rack-was very surprised at current value of racks.Hoping to find some experience out there with this.Trying to get information before were the guinea pig running the wheel.JJackson
pcar916 |
Apr 9 2011, 02:18 PM
Here's a link to the most up to date PET catalogs online at Porsche.
http://www.porsche.com/usa/accessoriesands...partscatalogue/ Punch in the year of your car and find the rack. The parts explosion will have the part numbers as well. Then you can call Sunset with them or give the numbers to the PP guys since their pricing may be better than Sunset. Good Luck! Ron |
jjackson |
Apr 9 2011, 02:31 PM
Thanks Ron! Will not be so nervous when destroying the originals.How big of a hammer do ya think I need?JJackson
pcar916 |
Apr 9 2011, 06:19 PM
Maybe not too big. (IMG:style_emoticons/default/piratenanner.gif) Those internal circlips can be a pain though and it's not uncommon to tear up the boss getting them out if you're not careful.
I don't see any seals or o-rings on the inside or outside of the bearings. But it is a greased rack rather than holding back liquid, and the boots will keep the dust out. I've never taken one apart but the bearings are either a slip fit or have to be pressed in and out. Regardless, you have access to plenty of presses around here fi you don't have one. Technically, if the bearings are in good shape you may only have to get one out anyway, unless the new rack and pinion set comes with new bearings... which I didn't notice on their website. Good luck! |
jjackson |
Apr 9 2011, 08:43 PM
Have had the part for over a year now.Took a while to get the rest of the car suspension handling the way we wanted it.Am I out on a limb here?I would have thought that there would be more interest out there.(Glad that we did not make such a highly desired-often sold out part)JJackson (IMG:style_emoticons/default/shades.gif)
jjackson |
Apr 10 2011, 04:00 PM
Okay, I'm the only one that thinks the steering should be slightly quicker when the car is handling the way that we want.I'm feeling a little bit like Rory M trying to stay on the front page.JJackson (IMG:style_emoticons/default/screwy.gif)
URY914 |
Apr 10 2011, 04:08 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,725 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Here's a tip when posting... put the subject of the thread in the topic title. "Quaiffe steering rack question" would have brought in a lot more viewers to your thread. Just a friendly tip from guy with a few posts under his avatar. (IMG:style_emoticons/default/biggrin.gif)
elmonte |
Apr 11 2011, 01:30 PM
Member Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 |
Very interested in this modification, always felt the steering should be a touch quicker.Not a cheap solution,but seems straight forward. Here's a few old Pelican threads on the steering rack rebuild that deals with pinion shaft bearing and rack replacement.
http://forums.pelicanparts.com/porsche-911...tml#post3096686 http://forums.pelicanparts.com/porsche-911...ng-replace.html If and when you give it a go, please post a thread on it. Cheers |
jjackson |
Apr 11 2011, 09:35 PM
Very interested in this modification, always felt the steering should be a touch quicker.Not a cheap solution,but seems straight forward. Here's a few old Pelican threads on the steering rack rebuild that deals with pinion shaft bearing and rack replacement. http://forums.pelicanparts.com/porsche-911...tml#post3096686 http://forums.pelicanparts.com/porsche-911...ng-replace.html If and when you give it a go, please post a thread on it. Cheers Thanks for the info.Planning on installing between Pro Solo in Blytheville and the National Tour in June.Have a third child due during that time frame also-so it might be wishful thinking.Will post info on install.Thanks again-JJackson (IMG:style_emoticons/default/stirthepot.gif) |
yeahmag |
Apr 11 2011, 11:11 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Very interested. Is there a link to the part?
Apr 11 2011, 11:33 PM
always felt the steering should be a touch quicker. The cheapest solution for that (free) is to adjust the toe. Run 1mm toe out in the front and 1mm toe in in the rear and then come back and tell me you still need "quicker" steering response ... (IMG:style_emoticons/default/rolleyes.gif) But, of course there's always a expensive high tech solution for any given problem. (IMG:style_emoticons/default/popcorn[1].gif) |
yeahmag |
Apr 11 2011, 11:42 PM
My issue is more in tight turns. I need more input than I can make without my hands leaving the wheel.
Apr 11 2011, 11:47 PM
My issue is more in tight turns. I need more input than I can make without my hands leaving the wheel. (IMG:style_emoticons/default/confused24.gif) My hands leave the wheel all the time. In tight turns i reposition my hand at least once or twice. Coming out of them sliding i actually let go on purpose as to not add too much input, otherwise you can overcompensate when you regain grip and the car goes into a spin. The way i was taught is to have "light" hands and let the car do most of the steering. Has worked for me so far. But, i understand that comes down to personal preference more than anything ... (IMG:style_emoticons/default/idea.gif) |
elmonte |
Apr 12 2011, 05:59 PM
Very interested. Is there a link to the part? Here it is http://www.quaife.co.uk/shop/products/qsf3q001-2 |
elmonte |
Apr 12 2011, 06:10 PM
always felt the steering should be a touch quicker. The cheapest solution for that (free) is to adjust the toe. Run 1mm toe out in the front and 1mm toe in in the rear and then come back and tell me you still need "quicker" steering response ... (IMG:style_emoticons/default/rolleyes.gif) But, of course there's always a expensive high tech solution for any given problem. (IMG:style_emoticons/default/popcorn[1].gif) What i meant by quicker steering is what Yeahmag said about less input with the steering wheel. Toe out just makes it too darty on the street. Cheers |
jmill |
Apr 12 2011, 07:09 PM
Lo-Fi Version | Time is now: 20th May 2024 - 11:20 PM |
