Alleluha! |
Alleluha! |
matteyp |
Apr 12 2011, 07:28 PM
Nothing a little JB Weld can't fix... Group: Members Posts: 263 Joined: 8-June 09 From: WA Member No.: 10,450 Region Association: Pacific Northwest |
My car finally turns over! Man I feel like a dummy. Had the positive side of the starter hooked to the negative side of the battery. Damn Germans and there black positive wires!!! hopefully I can get her running as soon as I can get the tank in and figure out clutch adjustment! Thanks for the all the help puget sound guys!
messix |
Apr 12 2011, 07:30 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/slap.gif)
(IMG:style_emoticons/default/shades.gif) good job on staying with it! |
clow |
Apr 12 2011, 08:17 PM
The Kid Group: Members Posts: 164 Joined: 7-September 10 From: Ontario, Canada Member No.: 12,151 Region Association: Canada |
My car finally turns over! Man I feel like a dummy. Had the positive side of the starter hooked to the negative side of the battery. Damn Germans and there black positive wires!!! hopefully I can get her running as soon as I can get the tank in and figure out clutch adjustment! Thanks for the all the help puget sound guys! Right on! I was in that position about 2 weeks ago. The cable had some wear and I had some heavy red cable around so I crimped on some new ends. Now its 'properly' color coded! Good luck with the rest of your project. Clow |
messix |
Apr 12 2011, 08:21 PM
first rule of electronics.... don't trust some one elses work, check where every conductor goes.
+ should not go to the bolt grounded at the body. unless you have one of Kelty360 cars!!!! [but those are all 6v cars.] |
scotty |
Apr 12 2011, 08:34 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
first rule of electronics.... don't trust some one elses work, check where every conductor goes. + should not go to the bolt grounded at the body. unless you have one of Kelty360 cars!!!! [but those are all 6v cars.] Ditto. I blew up an alternator that way (IMG:style_emoticons/default/headbang.gif) D'OH! |
Lo-Fi Version | Time is now: 17th May 2024 - 09:34 AM |
