31 Pages V « < 17 18 19 20 21 > »
> 914/6 resto warning, "rust"oration is more like it...
Gint
post Nov 10 2004, 06:05 PM
Post #361
Mike Ginter
QUOTE(restore2seater Posted on Nov 10 2004 @ 07:47 AM)
"I wish I could find the cowl corner replacement pics."
I am going to need to replace mine also. Did you ever find those pics? I would really like to see them if you can find them.
They can be made by a competent body guy. They're not that intricate. In my case, I had a donor tub. Look at the fenderless pic above. There is a close up of the driver's side cowl corner . That on was repaired instead of replaced.
QUOTE(Quebecer Posted on Nov 10 2004 @ 12:32 PM)
Mine is almost a copy, but unfortunately I haven't worked on it for one complete year.
Built my own house (larger garage), got married, and expecting a kid.
I must congratulate you on the great work you've done!
You're an inspiration for those days when I almost want to sell the project.
The body work and paint are being handled by folks that have the ability. I just tore it apart and will put it back together. And of course fork over $$$$$
Need two pieces of sheet metal - yesterday - Seat mount reinforcement thread
914/6 rusto \"while I'm in there\" question thread
Gint
post Nov 10 2004, 06:12 PM
Post #362
Mike Ginter
QUOTE(Eric_Shea Posted on Nov 10 2004 @ 01:32 PM)
Fender is on... looks great. I tried to take pics with a "real" camera but mine kept giving me a system error. I think it's just a low battery issue. Floor is out and the new one is going in today. Everything looks really clean.
Got 'em. Thanks! I'll post them next.
I'll try to get some shots nmaybe later today once the floor is in.
Keep 'em comin. Thanks Eric.
Gint
post Nov 10 2004, 06:13 PM
Post #363
Mike Ginter
Today's pics. The replacement fender is installed.
Gint
post Nov 10 2004, 06:14 PM
Post #364
Mike Ginter
reta
Gint
post Nov 10 2004, 06:15 PM
Post #365
Mike Ginter
reta
Eric_Shea
post Nov 10 2004, 08:38 PM
Post #366
PMB Performance
Who's that handsome mother fucher in that first pic... the one trying to get his camera to work?
(IMG:style_emoticons/default/w00t.gif)
restore2seater
post Nov 11 2004, 07:56 AM
Post #367
Future 914 copilot.
Mike, Eric
Actually the cowl area is the least of my problem areas right now. I was just curious what the replacement part looked like. The rust on the cowl area on my car is actually around the lower right windshield chrome area.
What are you using to remove your fenders? The areas look pretty clean and smooth where the spott welds were. Do you use some kind of bit in a drill? I bought a couple from Eastwood and would like to know if there is any trick to using them.
I do have a question off this topic though. How do you remove the hooks on the inside above the upper seat belt mount? For the clothes hangers to hang on. I'm stripping everything off the body and I don't want to destroy the padding around that area since it's in pretty good shape.
Gint
post Nov 11 2004, 09:54 AM
Post #368
Mike Ginter
QUOTE(restore2seater Posted on Nov 11 2004 @ 06:56 AM)
In a couple of months I can cut out the piece you need from my donor tub.
I don't really know what troy used for certain. I have a spot weld cutter, but you can use an ordinary drill bit. Do a google search for a spot weld cutter. In fact, you can do a search on this site as it's been discussed before.
Those plastic covers lift straight up and the metal bracket underneath has a phillips head screw holding it on. Really simple once you know that bit of info.
restore2seater
post Nov 11 2004, 10:04 AM
Post #369
Future 914 copilot.
This is the set of cutters I bought from Eastwood.
Gint
post Nov 11 2004, 10:05 AM
Post #370
Mike Ginter
Those will work. along with the standard arsenal of tools. It's not much fun, that's why I let Troy do all of that work. (IMG:style_emoticons/default/wink.gif)
restore2seater
post Nov 11 2004, 11:20 AM
Post #371
Future 914 copilot.
I've noticed that most of the repo places don't sell fenders. Most of the other body panels and frame pieces I need (longs, rockers, floor pans...) are available. Whats the best way to get front and rear fenders?
And no, I can't buy another car as a donor. Aggravated the wife too much already with my Challenger and now the 914.
Gint
post Nov 11 2004, 03:51 PM
Post #372
Mike Ginter
Donor tub. I have a left rear quater in really nice shape. Again, it's a couple of months from being available.
restore2seater
post Nov 11 2004, 04:05 PM
Post #373
Future 914 copilot.
Well I definitely need a right side rear fender but until I do some more diggin into the rest of the car I don't know about the left side. The front fenders have some DA marks showing through the paint and what looks like some bondo that wasn't featherd out to well. Probably PO work done at home rather than at a body shop. I would be interested in the left side rear though. And any other parts thats in good condition.
At this point if I had half a brain I should just part it out and find a better choice to restore but in central Illinois everything around here is going to have rust from the 70's.
I tried to remove that hooks above the seat belt the way you said and it won't move. Maybe I'm not being clear as to what I am trying to remove. These are attached on the inside about 2 inches up from the seat belt retractor. Their plastic and I assume they are used to hang clothes on. Although the location of the hooks makes me wonder how this could be done and still be able to see out the side windows.
Eric_Shea
post Nov 11 2004, 07:12 PM
Post #374
PMB Performance
Gint nailed it in his previous post. Take a flat-head and lightly pry up around the base and they should begin to lift like he said. Slide them up and you're good to go at the "actual" bracket that's under those covers.
restore2seater
post Nov 11 2004, 08:07 PM
Post #375
Future 914 copilot.
When you wrote "pry up" I took that literally. I took a screwdriver like you said and pryed out away from the side and that made it possible to pry up. I guess it was just a case of terminology. Thanks for the help.
Gint
post Nov 15 2004, 10:45 PM
Post #376
Mike Ginter
Forgot to post today's pics.
Gint
Post #377
Mike Ginter
Pans are in.
Gint
post Nov 15 2004, 10:47 PM
Post #378
Mike Ginter
New donuts and triangles too.
Gint
post Nov 15 2004, 10:48 PM
Post #379
Mike Ginter
Metal work is almost complete now.
Gint
Post #380
Mike Ginter
Rusty seal channel has all been repaired.
- Lo-Fi Version Time is now: 25th June 2026 - 02:09 AM
