terrible day, need to vent :), broken brakes, broken exhaust studs.... |
Mueller |
May 8 2004, 06:57 PM
started off the morning by deciding to finally redrill my rear brake rotors for my "strange" 4x100bc, drilled first hole, then I noticed a funny smell and smoke come out of the spindle motor for my small mill....motor decides to go kaput on me....I grab an extra electric motor I have, wrong shaft size, wrong mounting base, only one direction...
throw rotor on drill press, drill the remaining holes, now the more I look at the rotor, the less I want to use it...talk about piss poor planning, the new holes end up breaking thru into the large 3.54 diameter center hole....I don't feel comfortable at all with this setup...I wanted to sooner or later go with some custom rear rotors and calipers, now I am pretty much forced to do it now...the big pisser is that if I do the rear, I have to do the front since the available rear calipers are bigger than stock and will totally screw up the balance not too sure how I am going to break this to the wife, the cost is going to be ugly... and now for the really great news....about an hour ago, I broke an exhaust stud....now it's time to drill out the stud, helicoil and replace....this is how I f'd up my car 2 years ago which led me to "snap"...luckly, i am not as stressed and just shrugged my shoulders...it is not worth getting all bent out of shape about it...fix it, move on (IMG:style_emoticons/default/smash.gif) is it too early to (IMG:style_emoticons/default/beer3.gif) till I pass out (IMG:style_emoticons/default/wacko.gif) |
seanery |
May 8 2004, 06:59 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
bummer...have a beer.
Bruce Allert |
May 8 2004, 08:26 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Well... at least the engine is out & you don't have to lay under it whilst ya drill (IMG:style_emoticons/default/wink.gif) I was a bit luckier. Mine just stripped so I could redrill bigger & helicoil it.
Sorry to hear of the bad luck Mike. Isn't this #3? so yer done with the bad & every thing will go as planned, right? (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) Keeping mah fingers crossed fer ya (IMG:style_emoticons/default/wavey.gif) .....b |
Joe Bob |
May 8 2004, 09:05 PM
Bummer.....my day started out hectic as well .....took a run to the dump with my crappy rusty POS trailer....did the deed and took it up to 100 while acclerating briskly onto the freeway...... (IMG:style_emoticons/default/biggrin.gif)
Stopped of at Costco and was going to pick up my worker/helper, when I hit a speed bump at 15mph........FUCKINGBOOM........ (IMG:style_emoticons/default/unsure.gif) the rear axle seperated from the frame of the trailer......the tire came in contact with a sharp edge of the fender and exploded......whole axle got sideways dragging me to a stop......... SO.....after cleaning the brown stain, I went home and was able to get the broken exhaust stud to release with MAPP gas and Kroil.....Manfred is about ready to get the motor..... Frankie got the 2.2 in for fitment, the roof on my garage got torn off, 1/2 way redone on the 2x12 double ups....the guy that fell thru the drywall didn't kill himself, only bruised his ass.....so at least he and I ain't dead.....geez, what a bad time to give up Heroin.... (IMG:style_emoticons/default/confused24.gif) |
Gint |
May 8 2004, 10:08 PM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Hey Mike, Didya consider just throwin some used stock bits on it just to get it going instead dickin around with the fancy-schmansy shit? The exhaust stud is nothin...
Mueller |
May 8 2004, 10:49 PM
QUOTE Hey Mike, Didya consider just throwin some used stock bits on it just to get it going instead dickin around with the fancy-schmansy shit? The exhaust stud is nothin... I am trying just to throw it together with the stock stuff...the wheels are the only non-stock item right now, just a few more problems than i had expected with them. Just installed the dash (IMG:style_emoticons/default/smile.gif) , i had to do some minor trimming due to the roll cage...now it's time to hook up the gauges and stare at the wiring mess for an hour before I figure out what goes where, LOL |
May 9 2004, 09:54 AM
Hmm, I may have some spare rotors around here somewhere... Argh, no time to find them though!!
--DD |
ppickerell |
May 9 2004, 09:43 PM
914 addicted Group: Members Posts: 1,679 Joined: 14-October 03 From: Pleasanton, CA. Member No.: 1,246 |
Mike,
If you need any machining done, bring the stuff over and I can fix you up. patrick |
EdwardBlume |
May 9 2004, 09:55 PM
QUOTE about an hour ago, I broke an exhaust stud....now it's time to drill out the stud, helicoil and replace....this is how I f'd up my car 2 years ago which led me to "snap"...luckly, i am not as stressed and just shrugged my shoulders...it is not worth getting all bent out of shape about it...fix it, move on Zen and the art of 914 maintenance. (IMG:style_emoticons/default/biggrin.gif) |
Red-Beard |
May 9 2004, 10:15 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
I spent 2 hours trying to figure out why I had no power in the 914...
The PO or the PPO or the PPPO installed a new 12 wire which you have to slip under the nut when you install the battery cable on the + terminal... Yup, missed it... |
May 10 2004, 05:22 PM
Group: Posts: 0 Joined: -- Member No.: 0 |
Mike,
I'm not a big fan of helicoils, so I'd recommend using time-serts. They are much better. Go check them out. |
SLITS |
May 10 2004, 05:51 PM
QUOTE(Martin Baker @ May 8 2004, 05:06 PM) Mike, the ONLY reason I still own a 914 is I refused to let it beat me...my thought was if I can fix heavy fixed wing jets, I can correct any problem a 914 can send my way. I have been a mechanic for 22 years, and I let nothing suprise me, I just count on the worst, and do my best to make the repair happen correctly, whether it's a 747 or a 914, so hang in there. You will win. Hmmmmmmm <_< The 747 thing is really scarey. |
Lo-Fi Version | Time is now: 28th May 2024 - 09:17 AM |
