started off the morning by deciding to finally redrill my rear brake rotors for my "strange" 4x100bc, drilled first hole, then I noticed a funny smell and smoke come out of the spindle motor for my small mill....motor decides to go kaput on me....I grab an extra electric motor I have, wrong shaft size, wrong mounting base, only one direction...
throw rotor on drill press, drill the remaining holes, now the more I look at the rotor, the less I want to use it...talk about piss poor planning, the new holes end up breaking thru into the large 3.54 diameter center hole....I don't feel comfortable at all with this setup...I wanted to sooner or later go with some custom rear rotors and calipers, now I am pretty much forced to do it now...the big pisser is that if I do the rear, I have to do the front since the available rear calipers are bigger than stock and will totally screw up the balance
not too sure how I am going to break this to the wife, the cost is going to be ugly...
and now for the really great news....about an hour ago, I broke an exhaust stud....now it's time to drill out the stud, helicoil and replace....this is how I f'd up my car 2 years ago which led me to "snap"...luckly, i am not as stressed and just shrugged my shoulders...it is not worth getting all bent out of shape about it...fix it, move on
is it too early to till I pass out
