Throwing in the towel, waving the white flag :), going back to stock bolt pattern .... |
seanery |
May 10 2004, 09:40 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Jon, I was just getting ready to type that same question.
Mueller |
May 10 2004, 11:08 AM
on the front rotor, indexing it would interfer with the webing on the inside, not a modification I'd want to have to do to all 4 webs.
the rear flanges I had a buddy do at a shop, he should have indexed the new holes 45°, that way the rear rotors wouldn't be that big of deal..... |
Mark Henry |
May 10 2004, 11:52 AM
On those rims that Jon showed a pic of, they are called dual pattern.
One is the 100mmX4 VW/honda pattern, what is the other? |
Demick |
May 10 2004, 12:10 PM
Anyone know if our front rotors are shared with the '66-'79 VW beetle/ghia?? They look the same. If so, then you can just buy 4x100 front rotors. You can also buy native 5x130 front rotors:
custom VW rotors I'm guessing they are probably not the same or someone would have done this long ago. But ff they are the same, then this is the way to go. The rears are easy since the pattern can be indexed by 45 degrees. Demick |
Mark Henry |
May 10 2004, 12:42 PM
QUOTE(Demick @ May 10 2004, 10:10 AM) Anyone know if our front rotors are shared with the '66-'79 VW beetle/ghia?? They look the same. If so, then you can just buy 4x100 front rotors. You can also buy native 5x130 front rotors: custom VW rotors I'm guessing they are probably not the same or someone would have done this long ago. But ff they are the same, then this is the way to go. The rears are easy since the pattern can be indexed by 45 degrees. Demick Nope, just checked, the disc is about 10mm off. Wish they were the same because you can get blank rotors. |
Mueller |
May 10 2004, 12:48 PM
10mm how?? Diameter or ???
kdfoust |
May 10 2004, 06:39 PM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
QUOTE(Mueller @ May 10 2004, 10:48 AM) 10mm how?? Diameter or ??? Speaking of 10mm... Mike, I tried to buy some parts through your distribution network today. Knock off working on the hubs and make some rear trailing arm needle bearing kits... (IMG:style_emoticons/default/biggrin.gif) My car has requested one set. |
Mark Henry |
May 10 2004, 07:09 PM
QUOTE(Mueller @ May 10 2004, 10:48 AM) 10mm how?? Diameter or ??? The wheel face to the disc face, the 914 disc part sits back 10mm more. (I called this the backspace in the specs below.) This is approximate as I did it with a tape measure. There "could" be other differences, I didn't check. I have a new ghia rotor, right here in front of me, if you want all the specs. I don't have a 914 rotor off (or new) to check the specs on the race seats, etc. |
Mark Henry |
May 10 2004, 08:43 PM
A new ghia blank rotor drilled in the Porsche pattern.
The specs, backspace 2.120, inner bearing OD 1.985, outer bearing OD 1.590, seal seat 2.049, between bearing race seats 1.600 (+/- .010) and total lenght of hub 2.160 Attached image(s) |
Mark Henry |
May 10 2004, 08:46 PM
The back, notice no reinforcement ribs, the casting is thicker in this area so a blank can be drilled in almost any pattern.
Lo-Fi Version | Time is now: 10th June 2024 - 07:02 AM |
