'75 Heater Fan Parts and Hook Up |
euro911 |
Apr 15 2011, 12:00 AM
I didn't get a complete car when I bought my '75. Have acquired most of what was needed, but I'm finally trying to get heat into the car (just in time for summer, good timing, eh?) finding out a few heating items are needed.
This is what it looked like when purchased |
euro911 |
Apr 15 2011, 12:14 AM
I recently disassembled the fan, cleaned and painted it, ready to install it.
It only has a single outlet (unlike the one on my wife's '71 - with two outlets) and I don't know if it uses a 'Y' connector to get fan air into the two j-tubes? (IMG:style_emoticons/default/confused24.gif) |
AndyB |
Apr 15 2011, 05:33 AM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
IIRC later MY 75-76 had the Y connectors added again. Mine is an earlier MY 75 and doesnt have it. I know they are available from the usual places. Hope this helps.
type47 |
Apr 15 2011, 05:42 AM
I think MY75-76 did have the "Y" for hoses to both sides of the motor but will defer to experts as I can't tell from the PET 202-15 about the blower motor and hoses. At the good Dr's site you probably could find some diagrams of the parts and info in their catalog...
jim_hoyland |
Apr 15 2011, 06:36 AM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Mark,
I see the Y connectors sold at the G & R almost every year. I removed my heather fan after installing SS heat exchangers. Within 2 minute of starting and pulling back on the red heater lever, heat coming into the cabin. Doesn't leak when closed. |
SLITS |
Apr 15 2011, 07:01 AM
Factory decided it didn't need both exchangers, so they went to a single feed. Splitter is available to feed both of them.
76-914 |
Apr 15 2011, 07:57 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
So you only need one, huh? No wonder mine works so well. Yes, they do have a splitter that mounts on the fan shroud, itself. Contrary to Jim's car mine does not leak warm air into the cabin.
Sleepin |
Apr 15 2011, 09:27 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
The 75 and 76 exhaust was just that much more efficient. (IMG:style_emoticons/default/rolleyes.gif)
Plenty of heat just using one side though. |
jim912928 |
Apr 15 2011, 09:35 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
my 75 had the Y connector. Should be able to get one on here if you do a WTB in classifieds...just saw one on ebay also....here is the link:
http://cgi.ebay.com/ebaymotors/Porsche-914...es#ht_500wt_749 |
euro911 |
Apr 15 2011, 10:53 AM
The famous 'Bat Mobile' has early style S/S H/E, hence two j-tubes. I thought about only hooking up one side and capping off the other, but I remember someone else telling me that it could cause overheating on the capped side.
Thanks for all the input ... I'll keep me eyes open for a 'Y' at G&R |
Sleepin |
Apr 15 2011, 12:14 PM
Let me know Mark, iffin you really need one and if I can find my extra, it is yours. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/popcorn[1].gif)
Drums66 |
Apr 15 2011, 12:24 PM
I recently disassembled the fan, cleaned and painted it, ready to install it. It only has a single outlet (unlike the one on my wife's '71 - with two outlets) and I don't know if it uses a 'Y' connector to get fan air into the two j-tubes? (IMG:style_emoticons/default/confused24.gif) ....Excellent detail job on the fan! (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/thumb3d.gif) (did they come like that ?lol) (IMG:style_emoticons/default/bye1.gif) |
Apr 15 2011, 03:52 PM
The 70-72 fan has two separate outlets, on opposite sides of the shroud.
The 73-74 fan has a single outlet, which was ducted to the left-side exchanger only. The top of the J-tube on the right side was capped off with a plastic cap and a hose clamp. The 75-76 fan has a single outlet, but that outlet has a Y fitting on it. The outlet replaces the part you can see in the photo that has a square inlet and a round outlet; on the later fans it has two round outlets. It sounds like early 75s used the 73-74 style of fan, which presumably means the right side J-tube is capped off. You can do that pretty easily (I think a spray paint cap fits well) as a permanent solution or as a temporary one until you get the Y. --DD |
Lo-Fi Version | Time is now: 20th May 2024 - 08:11 PM |
