euro911
Apr 15 2011, 12:00 AM
I didn't get a complete car when I bought my '75. Have acquired most of what was needed, but I'm finally trying to get heat into the car (just in time for summer, good timing, eh?) finding out a few heating items are needed.
This is what it looked like when purchased
euro911
Apr 15 2011, 12:14 AM
I recently disassembled the fan, cleaned and painted it, ready to install it.
Click to view attachmentIt only has a single outlet (unlike the one on my wife's '71 - with two outlets) and I don't know if it uses a 'Y' connector to get fan air into the two j-tubes?
AndyB
Apr 15 2011, 05:33 AM
IIRC later MY 75-76 had the Y connectors added again. Mine is an earlier MY 75 and doesnt have it. I know they are available from the usual places. Hope this helps.
type47
Apr 15 2011, 05:42 AM
I think MY75-76 did have the "Y" for hoses to both sides of the motor but will defer to experts as I can't tell from the PET 202-15 about the blower motor and hoses. At the good Dr's site you probably could find some diagrams of the parts and info in their catalog...
jim_hoyland
Apr 15 2011, 06:36 AM
Mark,
I see the Y connectors sold at the G & R almost every year. I removed my heather fan after installing SS heat exchangers. Within 2 minute of starting and pulling back on the red heater lever, heat coming into the cabin. Doesn't leak when closed.
SLITS
Apr 15 2011, 07:01 AM
Factory decided it didn't need both exchangers, so they went to a single feed. Splitter is available to feed both of them.
76-914
Apr 15 2011, 07:57 AM
So you only need one, huh? No wonder mine works so well. Yes, they do have a splitter that mounts on the fan shroud, itself. Contrary to Jim's car mine does not leak warm air into the cabin.
Sleepin
Apr 15 2011, 09:27 AM
The 75 and 76 exhaust was just that much more efficient.
Plenty of heat just using one side though.
jim912928
Apr 15 2011, 09:35 AM
my 75 had the Y connector. Should be able to get one on here if you do a WTB in classifieds...just saw one on ebay also....here is the link:
http://cgi.ebay.com/ebaymotors/Porsche-914...es#ht_500wt_749
euro911
Apr 15 2011, 10:53 AM
The famous 'Bat Mobile' has early style S/S H/E, hence two j-tubes. I thought about only hooking up one side and capping off the other, but I remember someone else telling me that it could cause overheating on the capped side.
Thanks for all the input ... I'll keep me eyes open for a 'Y' at G&R
Sleepin
Apr 15 2011, 12:14 PM
Let me know Mark, iffin you really need one and if I can find my extra, it is yours.
Drums66
Apr 15 2011, 12:24 PM
QUOTE(euro911 @ Apr 14 2011, 11:14 PM)
....Excellent detail job on the fan!
(did they come like that ?lol)
Dave_Darling
Apr 15 2011, 03:52 PM
The 70-72 fan has two separate outlets, on opposite sides of the shroud.
The 73-74 fan has a single outlet, which was ducted to the left-side exchanger only. The top of the J-tube on the right side was capped off with a plastic cap and a hose clamp.
The 75-76 fan has a single outlet, but that outlet has a Y fitting on it. The outlet replaces the part you can see in the photo that has a square inlet and a round outlet; on the later fans it has two round outlets.
It sounds like early 75s used the 73-74 style of fan, which presumably means the right side J-tube is capped off. You can do that pretty easily (I think a spray paint cap fits well) as a permanent solution or as a temporary one until you get the Y.
--DD
