Hershey parts list |
saigon71 |
Apr 20 2011, 06:53 AM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
In the market for the following:
The long metal passenger rear brake line (the one that runs from the rear brake controller to the wheel) Eyebrow grommets Flexible brake lines - new (all four) CHT sensor - 1974 2.0 Stainless steel fuel line set Will be up on Saturday. |
okieflyr |
Apr 20 2011, 10:18 AM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Apr 20 2011, 10:34 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I will also have a VERY nice 356 C model front clip ( headlights forward, no rust no accident ). How much do you want for this and can you send me a few pics? Rich Probably 1500.00 You'll see it Friday or saturday (IMG:style_emoticons/default/rolleyes.gif) just so you dont get disappointed and end up dragging it home...Stoddards (who will be there) sells the front nose halves new for 400 each...so 800 per pair for new sheet metal. Look around at them before you drag it out, they sell out early of the nose pieces typically, so if you pull it out afterwards, you may win out. They also sell the T5B nose pieces...and those can be modified to create an A nose with VW headlight buckets. Rich |
ChrisFoley |
Apr 20 2011, 08:07 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
In the market for the following: ... Stainless steel fuel line set I'll be there with SS fuel lines and lots of other things! (IMG:style_emoticons/default/smile.gif) |
tod914 |
Apr 20 2011, 08:21 PM
Looking for a 73 rear chrome bumper. Thanks.
ArtechnikA |
Apr 22 2011, 03:56 PM
While looking through stuff in the garage I came up with some more stuff I'll be adding to the pile...
Nice lo-miles pair of slotted, vented front brake disks. 2,2 pushi-me-pulli-you clutch pressure plate RSR-valved Bilstein Rallye front dampers for '65-mid-'85 Boge struts. These are _not_ street dampers... New, never-installed, all hardware, original boxes. Unused set of Koni-strut red (adjustable, but not externally-adjustable) Koni dampers, 911 valving, OK for 914. (But don't go crazy with lowering or you'll damage the adjusting valve...) And the ever-popular - 'more' ... |
zymurgist |
Apr 22 2011, 04:04 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I got 2 Fuchs with tires. They are 15x8.
Lo-Fi Version | Time is now: 9th June 2024 - 11:44 PM |
