Best Dizzy with Carbs?, Thinking about a mallory |
May 10 2004, 04:30 PM
To many choices with the mallory at ACN...
Help me make the right choices please... Rich |
machina |
May 10 2004, 04:38 PM
i got the mallory #4554101
It is not the vacum advance model, uses different color springs to adjust advance. Jake likes this one but others prefer the one with vacum. dr |
skline |
May 10 2004, 04:51 PM
I just used an 050, worked great.
Jake Raby |
May 10 2004, 05:18 PM
worked great compared to what...
The 050 is the bottom of my list for good dizzies, they rub at zero-2 degrees to get 28 full... so most guys jack them to 32 full to get a decent idle and then they overadvance the top end and fry the heads because it feels faster. Nothing beats a mallory, got the p;lots to prove it, and the ones to prove that an 050 is the laziest thing on the planet at idle. When the camshaft changes the issues with the 050 are made worse, as the valve timing cahenges you can run 11-14 degrees of iniotial advance and the car will run better akll around and produce 25% more power in the advance curve. I have a mallory in everything I own, even my Chevy truck that we tow stuff with- AWESOME |
SpecialK |
May 10 2004, 05:20 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Okay Jake....To vacuum, or not to vacuum?
MattR |
May 10 2004, 05:51 PM
How about the mallory versus the Aircooled.net SVDA distributor? Is it really worth the 180 on a tight budget? I dont want to be stupid and get a bad dizzy and rob my horsepower, but if its just a slight difference at xxxx rpm, then I dont mind.
Jake Raby |
May 10 2004, 06:06 PM
The SVDA is not nearly as adjustable.... It still uses the stock cap with cloely positioned contacts, and must use a pertronix or other "toy" replacement to get rid of the points.
Mallory. |
skline |
May 10 2004, 06:53 PM
Well, I went with teh 050 because that is what everyone here said to use when I bought it. The car is sold now so its not my problem anymore. The bird board said the same thing. It was about 2 years ago when I needed it.
tommy914 |
May 11 2004, 07:48 PM
Life is a journey, enjoy every turn. Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
What is a good source for the Mallory?
lapuwali |
May 11 2004, 08:39 PM
Aircooled.net is a good source. However, right this second, it appears to be nearly impossible to get the non-vac Mallory from any of the usual vendors, including Aircooled.net. Mallory is apparently taking their time shipping them out to their retailers. I've had one on order for nearly a month.
Jake Raby |
May 11 2004, 09:25 PM
I have zero in stock and am dead in the water.. cannot even dyno any engines...
machina |
May 12 2004, 06:15 AM
Jake Raby |
May 12 2004, 06:18 AM
Nope, he's been out for a month..
Lo-Fi Version | Time is now: 12th May 2024 - 01:47 PM |
