What needs to be machined, what parts of the engine |
914curt |
Apr 14 2003, 04:16 PM
Newbie Group: Members Posts: 15 Joined: 12-February 03 From: Chicago, IL Member No.: 306 |
If I was going to decide to rebuild this engine of mine what parts do i have to send ot the machine shop, and where is a good place t send it ot to. i think that i am going to tear it down and rebuild it, start over that way i know what i have not guessing at everything because i don't know what the last guy did.
Curt |
URY914 |
Apr 14 2003, 05:52 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Is it a -4 or -6?
If it is a -4 go to www.shoptalkforums.com for all your engine needs. If it is a -6 get a copy of Bruce Anderson's book or Wayne's book at Pelican Parts for all the details. Not that people here can't help you, but these will give you a starting point and hours of reading pleasure and than come back with more questions. |
Brad Roberts |
Apr 14 2003, 06:18 PM
Curt,
Most of us buy new pistons/cylinders Your crank may or may not need turning (I normally have them micro polished) Your rods will need to be resized on the large end and rebushed on the small end (this is fairly inexpensive and cheap insurance) I have the case inspected (main bearings saddles are starting to show wear in 60% of the cases we have pulled apart) and the rear main bearings holders are showing wear. Heads: I have a fresh set of rebuilt 1.8 heads that I had done for 350$ (for sale) with new springs keepers the whole enchilada. Balance the entire rotating and reciprocating assembly (normally 100$ or so) New cam and lifters (200$ from WebCam) Honestly.. I wouldnt rebuild a 1.8 unless it was going into a 1.8 concourse car (which I would never build) Buy a core 2.0 (like the one listed here for 700$ complete) and rebuild a 2.0. The price runs very close to the same for rebuilding a 1.8 as it does a 2.0 B |
Lo-Fi Version | Time is now: 20th May 2024 - 05:39 AM |
