Any D-jet troubleshooters in the NY, CT, MA area?, My 2.0 is too rich for traffic behind me |
4WheelDrifter |
May 10 2004, 05:42 PM
Having a mid-life crisis @ 35 Group: Benefactors Posts: 201 Joined: 15-April 04 From: Bethel, CT Member No.: 1,934 |
Subject says it all.
I'd like to find a good troubleshooter for my D-Jet 2.0. It's running rich as hell (stinks). I'd like to find out what's wrong with it to make it run better and cleaner. Plus with gas prices as they are, I wouldn't mind a few more MPG. Thanks! |
Part Pricer |
May 10 2004, 06:30 PM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
I would think that Ed Morrow could give you some good suggestions. Ed is just north of the border in Massachusetts (That's right, he's a Mass-hole) (IMG:style_emoticons/default/wink.gif) His 914Club ID is ejm.
You might also want to check with Chris Foley. I'm not sure if he's a FI guy, but he could steer you in the right direction. |
ejm |
May 10 2004, 06:48 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
I don't think too many are left....
Take a look at Brad Anders D-jet webpage for troubleshooting ideas. Often the problem is mis-matched components or something simple like a vacuum leak that's been overlooked. If all else fails I have both the Bosch and Grundig D-jet testers. It's been decades since they were used but should still work. You guys going to the meeting tomorrow night? |
4WheelDrifter |
May 10 2004, 07:01 PM
Paul, Don't think Chris does FI either but he might know. I'll give him a call.
ejm, Thanks. I'll have to run down the checks on Brad's site. Meeting? Probably can't make it, getting a timing belt replaced on my truck. It's way overdue. |
Carrera916 |
May 10 2004, 07:29 PM
Member Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 |
Since you're in Conn, you might want to try call Gerry at KAM Motorsports and see if he can help.
KAM Motorsports WWW.KAMMotors.com 203.754.1547 Let me know how you make out with that J |
Kerrys914 |
May 10 2004, 07:52 PM
My 2.0L had a gas smelling smoking problem last fall. I had one injector that was leaking bad and causing the engine to run rich (IMG:style_emoticons/default/smile.gif) I actually had fuel coming out the exhaust port and running down the heat exchangers (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/ohmy.gif)
If the injectors are old have them cleaned. It will make a world of difference and @ $11/injector it's cheap too. I am proud to say I am have been smoke free for 9 months (IMG:style_emoticons/default/smilie_pokal.gif) Cheers Kerry |
Bleyseng |
May 10 2004, 07:55 PM
Does it start?
Check the CHT first... Then test the MPS for leaks, it should hold a 15hg vacunnm for 5 minutes. Check the fuel pressure to see if the return line is plugged. |
ChrisFoley |
May 10 2004, 08:18 PM
I am Tangerine Racing Group: Members Posts: 7,924 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I can work on D-Jet but I don't have any specialized equipment such as the units Ed mentioned.
william harris |
May 11 2004, 05:55 AM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
(IMG:style_emoticons/default/smile.gif) Call Richard Anzalone at Autobahn Performance in Peabody, MA (978) 536-2667. Richard is a Porsche mechanic of more than 25 years experience and a 914 owner. He certainly can work on D-Jet. Good Luck and keep it running. (IMG:style_emoticons/default/clap56.gif)
lmcchesney |
May 11 2004, 06:00 AM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
Chris would be a good choice. Also, there is the group in suburbs of Boston that performed the Grassroots Motor Sports project. Do search for GRMS. Although, they did have problems after they built the motor.
L. McC |
ynotdd |
May 11 2004, 06:11 AM
Member Group: Members Posts: 156 Joined: 13-January 03 From: plainview, NY Member No.: 140 |
Call PSH 16313215100 ask for Kevan. he has been a porsche mech for 30 years and specializes in 914's.He in Long Island NY, in ct try chris foley
May 11 2004, 06:48 AM
4WheelDrifter |
May 11 2004, 07:41 AM
Wow, thanks guys.
Dead Air |
May 11 2004, 09:02 AM
Senior Member Group: Members Posts: 1,268 Joined: 9-May 04 From: Buffalo, NY Member No.: 2,042 |
Thanks for a great response. If we ever get this motor pulled, I know I'll find it usefull. We'd like to stay mostly stock.
We're looking for members in the western NY, NW PA, southern Ontario area. |
Lo-Fi Version | Time is now: 12th May 2024 - 05:07 AM |
