Transmission Woes, Popping out, Grinding, WTF? |
iiibdsiil |
May 10 2004, 07:59 PM
Needs Door Locks Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 |
Okay, let's see where to being.
I have a 901 box. Side shifter. Gears: 1st: almost always works, pops out occasionally. I don't use it enough though. 2nd: been being a real bitch as of today. More often than not, it will not go in. Not going in defined as in like hitting a brick wall. Just refuses, although sometimes on multiple, read more than 5 attempts in a row, will it drop in. Pops out very very very rarely. 3rd: Been a bitch for about 2.5 months. Pops out a lot. More often than not, it will not go in. Refer to definition under 2nd gear. When 2nd works today, 3rd works most of the time, but not guranteed, and seems to be getting more towards not working when 2nd is working, most of the time. 4th: My baby. Always works no matter what. Although when I down shift with clutch fully pushed down, it grinds bad going near and into third. 3rd probably needs synchro, huh? 5th: Don't use much either, even on the highway. It's a flipped 3rd, H. Was a real good gear, just about a month ago it decided it didn't want to go in the first one or two tries. It would grind, and pop out, or not even go in, just grind. I am beginning to think it has something to do with the /6 mount I have. It is the Patrick bar, and I know people have had problems with those. It almost seems like the motor is like resting on the shift rod. I think that maybe the rod it getting jammed up somewhere outside of the tranny. But, I also don't believe that. Lol. Like, maybe there is tension on the rod, and it is pulling the tranny out of gear. The bushings between the firewall and the tranny were replaced about 5 months ago, I did them personally, before I bought the car. Does anyone have any ideas? I don't know anything about the gear boxes, besides what the gear looks like. So, I could pull it apart, but I really don't want to if I don't have to. It needs to be fixed internally now, because of the problem, just wondering if anyone has any ideas what it could be, and what not. Thanks guys. - Brett Smith |
Kerrys914 |
May 10 2004, 08:13 PM
Try this;
- Disconnect the shift rod from the shifter or tranny - Remove the black plastic cover from the rear of the tranny linkage. - From the rear (using the pivot linkage under the plastic cover) of the tranny, shift the tranny into 1st gear. Test drive and see if it pops out of gear. If it doesn't you have a linkage problem. (IMG:style_emoticons/default/biggrin.gif) If it still pops out you have tranny problems. (IMG:style_emoticons/default/sad.gif) Hope this makes sence?? Cheers (IMG:style_emoticons/default/beerchug.gif) |
john rogers |
May 10 2004, 08:23 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I'd say check your motor and tranny mounts. When they tear or break you can get the symptoms you have.
iiibdsiil |
May 10 2004, 08:54 PM
How do I check the /6 mount. And if it is bad, how bad to replace?
- Brett Smith |
iiibdsiil |
May 10 2004, 08:55 PM
QUOTE(Va914 @ May 10 2004, 09:13 PM) Try this; - Disconnect the shift rod from the shifter or tranny - Remove the black plastic cover from the rear of the tranny linkage. - From the rear (using the pivot linkage under the plastic cover) of the tranny, shift the tranny into 1st gear. Test drive and see if it pops out of gear. If it doesn't you have a linkage problem. (IMG:style_emoticons/default/biggrin.gif) If it still pops out you have tranny problems. (IMG:style_emoticons/default/sad.gif) Hope this makes sence?? Cheers (IMG:style_emoticons/default/beerchug.gif) I like that idea. I will mess with it tomorrow, if I get an opportunity. - Brett Smith |
iiibdsiil |
May 10 2004, 10:09 PM
Oh yeah, I forgot to mention:
When I put it in gear, and can tell it is going to pop out, I can physically hold it in. Not sure if that makes any difference. - Brett Smith |
Lo-Fi Version | Time is now: 19th May 2024 - 03:11 AM |
