Rust repair ROOKIE!, That welder is HOT! |
dinomium |
May 11 2004, 11:25 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
Ok this is what a dime size rust hole is undernieth:
(IMG:style_emoticons/default/blowtorch.gif) Attached image(s) |
dinomium |
May 11 2004, 11:26 PM
and now it looks like this: (IMG:style_emoticons/default/welder.gif)
This is just above the well for your hand at the door handle... Attached image(s) |
ablose58 |
May 12 2004, 01:36 AM
rust never sleeps Group: Members Posts: 584 Joined: 6-December 03 From: port orchard,wa. Member No.: 1,422 |
Not too shabby for a rookie, Dino. When do you want me to come over to do those u-tabs? sat. is open as of now! AL
red914 |
May 12 2004, 07:48 AM
...i believe in coyotes and time as an abstract... Group: Members Posts: 862 Joined: 8-February 04 From: poulsbo, washington Member No.: 1,641 |
looks good! of course, now i am afraid to investigate the little bubble in the paint i have in exactly the same spot... (IMG:style_emoticons/default/sad.gif)
DNHunt |
May 12 2004, 08:44 AM
Dino
That looks great. If you don't have to do too much it's kinda fun. Get's old when you keep finding more. Is this the Gulf 914. Go Dino, Go. I can't wait to see that. Dave |
maf914 |
May 12 2004, 08:50 AM
Okay, I guess I'm a dummy. What part are we looking at here?
TheCabinetmaker |
May 12 2004, 08:53 AM
below sail panel. above door handle cutout
914werke |
May 12 2004, 10:33 AM
"I got blisters on me fingers" Group: Members Posts: 10,052 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/smilie_pokal.gif) I have to do that same thing..on both sides of the 73 (IMG:style_emoticons/default/mad.gif)
Were the other trim holes equally rotted? |
dinomium |
May 12 2004, 10:42 AM
Thanks, guys... It was only the one hole one the drivers' side. If I had to do it again, I might just replace the whole sail peice. I don't think it would be much harder and easier to line up!!
Too bad I have to work on the House Saturday so I can go to the PCA stuff on Sunday... such is life! (IMG:style_emoticons/default/lol2.gif) |
thesey914 |
May 12 2004, 11:07 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Nice job....I had a pro do mine as it seemed a bit tricky..your's looks just as good.
Gint |
May 12 2004, 04:15 PM
Mike Ginter Group: Admin Posts: 16,070 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Great work!
QUOTE looks good! of course, now i am afraid to investigate the little bubble in the paint i have in exactly the same spot... If you have bubbles in your paint, DON'T mess with 'em unless you're ready to do rust repair. Because that is wht you'll find when you attack the bubble. I used to deceive myself... not anymore. I learned. |
aircooledboy |
May 12 2004, 04:21 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
I've got 2 spots exactly that size on an otherwise very clean car. You guys are REALLY bringin me down. (IMG:style_emoticons/default/blink.gif)
Oh ya, BTW, very nice work. Only time I ever tried to weld a repair, it looked like a poorly trained chimp did it. (IMG:style_emoticons/default/smash.gif) |
dinomium |
May 12 2004, 05:13 PM
Thanks, guys... it really isnt that bad. I did work in a boat yard for two summers. I got some made GRINDER skillz!
But if you arent ready to cut it out, then you got to leave it alone! You mom was right, if you pick at it, it will get infected!!!! (IMG:style_emoticons/default/happy11.gif) |
SpecialK |
May 12 2004, 05:14 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
What is it about that location? (IMG:style_emoticons/default/huh.gif)
I've got exactly the same rust problem on both sides that the PO attempted to repair. I'll have to cut it out and do what you did. (IMG:style_emoticons/default/welder.gif) |
Eric_Shea |
May 12 2004, 05:24 PM
Did you say something Kevin? (IMG:style_emoticons/default/blink.gif)
ChrisFoley |
May 12 2004, 06:02 PM
I am Tangerine Racing Group: Members Posts: 7,924 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
QUOTE(Special_K @ May 12 2004, 07:14 PM) What is it about that location? (IMG:style_emoticons/default/huh.gif) The factory, in it's infinite wisdom, filled the area with foam and covered that with a sealer. After a few years the sealer delaminates from a small area (at first) of the bodywork and lets moisture into the foam. The foam holds onto the moisture and creates a perfect environment for iron oxide formation. Most of the typical rust prone areas on our cars are where moisture resides after the undercoating or body schutz fails. |
East coaster |
May 12 2004, 06:40 PM
Senior Member Group: Members Posts: 1,668 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Wow...........It must be drivers side rust bubble week! I just finished ice picking the bubble, cutting out the affected area and butt welding in a patch.
Your repair looks very good, you're lucky you didn't have to go into the handle recess area like I did. Thank God for MIG, if you torch this area (or TIG) you'll have to deal with the brass the factory used in the area around the vent hole. With MIG it never got hot enough to disturb the brass. Since we're playing I'll show mine if you show me your's, here's mine>>>>>> Attached File(s) rust_repair_002.JPE ( 14.96k ) Number of downloads: 0 |
thesey914 |
May 13 2004, 12:48 AM
QUOTE(Eric_Shea @ May 12 2004, 03:24 PM) Did you say something Kevin? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/biggrin.gif) ....Yeah I couldn't tear my eyes away from that ass either.... |
Eric_Shea |
May 13 2004, 05:16 PM
Here's mine...
Lo-Fi Version | Time is now: 10th May 2024 - 04:40 AM |
