Clutch ?, You got some splainin to do |
Rocky |
May 12 2004, 07:26 AM
From the cockpit Group: Members Posts: 341 Joined: 24-March 04 From: Gig Harbor,WA Member No.: 1,845 |
While performing my favorite pastime of sleeping under my teener, I looked deeper into my clutch. (IMG:style_emoticons/default/ph34r.gif)
Is the throwout bearing always in contact with the preassure plate?? It appears it must be given there is always a certain amount of cable tension. Just a thought... and does it put undue wear on the throwout bearing? Tim |
DNHunt |
May 12 2004, 08:02 AM
Tim
Mine sure seems to be. The fork appears to hold the throw out bearing against the springs on the pressure plate. There doesn't appear to be any way around this so it must be the way it was designed. Last thing I have to do to get mine on the road again after the weekend marathon is adjust the clutch. (IMG:style_emoticons/default/clap56.gif) All that's left to do before leaving for WCC is change the oil and filter and plugs then clean up and pack. Dave |
aircooledboy |
May 12 2004, 09:40 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
It will make contact, but that is why you should have free play (aprox 1/2 inch as I recall) at the top of the clutch pedal. As long as the cable isn't "preloaded" so that it is putting any real tension on the fork before you step on the pedal, any wear on the bearing is minmal and unavoidable.
Or, Reader's Digest Version: As long as yo' cable adjusted right, ain't no thang. (IMG:style_emoticons/default/cool.gif) |
May 12 2004, 09:48 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The "helper" spring in the pedal cluster keeps a little bit of tension on the cable, so the throwout bearing does always contact the fingers of the clutch diaphragm spring. Far as I can tell, that's to make sure the cable does not develop enough slack to jump off of the roller back on the transmission.
The "free play" in the clutch pedal is generally measured by pulling up on the pedal. --DD |
aircooledboy |
May 12 2004, 09:57 AM
QUOTE(Dave_Darling @ May 12 2004, 09:48 AM) The "free play" in the clutch pedal is generally measured by pulling up on the pedal. --DD And that is why I will never be more than a fool with a teeny bit of dangerous knowledge, a giant shop and a lot of really cool tools. (IMG:style_emoticons/default/wacko.gif) Dave on the other hand, "Da Man". |
Rocky |
May 12 2004, 01:31 PM
Much appreciated gentlemen. (IMG:style_emoticons/default/beerchug.gif) Ive had many other vehicles and the throwout bearing never engages the pressure plate until pedal pressure is applied.
Thanks for confirming my suspicions. Tim |
Lo-Fi Version | Time is now: 12th May 2024 - 08:58 AM |
