2.7l (6) CIS Linkage?, Anyone got a picture or can take one? |
bfrymire |
Apr 18 2011, 04:27 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Help.
I am in the process of converting from carbs back to CIS. (EFI conversion see my thread.) The carb angle and motion does not appear to be correct. So, I am looking to see what it should look like. (If i am missing parts, then I am in the market for parts. (IMG:style_emoticons/default/smile.gif) ) -- brett |
SLITS |
Apr 18 2011, 05:12 PM
I will shoot an image for you tomorrow, but until then ....
I use the 914/6 bellcrank on the tranny, with the 914/6 long steel rod up the the CIS bellcrank console. From the console, it is a short rod to the throttle body. I have, on a previous conversion, made a bracket and bolted it to the CIS console. I used a standard /4 throttle cable, but drilled an pinned the end with the snap connector to fit over the ball on the throttle body. |
bfrymire |
Apr 18 2011, 08:16 PM
I will shoot an image for you tomorrow, but until then .... I use the 914/6 bellcrank on the tranny, with the 914/6 long steel rod up the the CIS bellcrank console. From the console, it is a short rod to the throttle body. I have, on a previous conversion, made a bracket and bolted it to the CIS console. I used a standard /4 throttle cable, but drilled an pinned the end with the snap connector to fit over the ball on the throttle body. Thanks! Here's a picture to show the problem. You can see that the throttle body needs to move up and down, and the carb linkage moves forward and backward. Really, hope you can shed light on this. If you see parts missing, etc, I would appreciate the illumination. (IMG:style_emoticons/default/smile.gif) Another image for clarity. |
SLITS |
Apr 18 2011, 08:32 PM
You can run a link like the black line (standard CIS part) and it will work.
or Move the cable assembly over in line with the TB connector and run the cable directly to the connector on the throttle linkage. You may have to lengthen the cable by some means. |
bfrymire |
Apr 18 2011, 09:48 PM
You can run a link like the black line (standard CIS part) and it will work. or Move the cable assembly over in line with the TB connector and run the cable directly to the connector on the throttle linkage. You may have to lengthen the cable by some means. Thanks Ron! I will give that a shot. -- brett |
bfrymire |
Apr 21 2011, 12:23 AM
You can run a link like the black line (standard CIS part) and it will work. or Move the cable assembly over in line with the TB connector and run the cable directly to the connector on the throttle linkage. You may have to lengthen the cable by some means. Ron, Didn't work. It gets part throttle, then binds. (IMG:style_emoticons/default/sad.gif) Any other ideas? Need to get this to work soon. Getting close to firing the motor. -- brett |
bfrymire |
Apr 21 2011, 01:21 AM
Attached thumbnail(s) |
Scott S |
Apr 21 2011, 10:25 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
I have a full CIS system (less the fuel pump)in a box that I will never use. I know it was in 100% perfect working order when it was pulled off of the car 2 years ago. It has the full linkage. You can have it for the price of shipping. Only caveat is that it will probably take me a week or so to get it out of storage.
Dr Evil |
Apr 21 2011, 11:39 AM
Send me your transmission! Group: Members Posts: 23,001 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Extend the cable to connect directly to the TB (no bell crank). Still not direct, though.
Better yet, rotate the TB clockwise 90 degrees THEN connect the cable. It will be a direct pull down (IMG:style_emoticons/default/wink.gif) |
Dr Evil |
Apr 21 2011, 11:40 AM
The only reason for bell cranks is to change the ratio of travel so that full pedal travel = WOT.
Lo-Fi Version | Time is now: 27th May 2024 - 10:41 AM |
