QUOTE(SLITS @ Apr 18 2011, 04:12 PM)
I will shoot an image for you tomorrow, but until then ....
I use the 914/6 bellcrank on the tranny, with the 914/6 long steel rod up the the CIS bellcrank console. From the console, it is a short rod to the throttle body.
I have, on a previous conversion, made a bracket and bolted it to the CIS console. I used a standard /4 throttle cable, but drilled an pinned the end with the snap connector to fit over the ball on the throttle body.
Thanks!
Here's a picture to show the problem. You can see that the throttle body needs to move up and down, and the carb linkage moves forward and backward.
Really, hope you can shed light on this. If you see parts missing, etc, I would appreciate the illumination.
Click to view attachmentAnother image for clarity.
