Stuck compression tester, how to remove it? |
VaccaRabite |
Apr 18 2011, 06:39 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have a compression tester stuck in Cyl 4 (one of the deep ones).
the rubber spins, but where it threads in is tight and won't thread out. Any clue as to how to get the darned thing out? Without cutting the rubber to get a pair of needle nose pliers in there? over 160 compression, so at least thats good. :-) (turned out the cylinder was not firing due to a plugged idle jet. Which I had guessed. But I was curious about the compression. Something about killing a cat...) Zach |
scotty b |
Apr 18 2011, 06:45 PM
rick 918-S |
Apr 18 2011, 06:48 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Oh dude.... (IMG:style_emoticons/default/sad2.gif) Wiggle it while you turn it. Or just cut the hose. (IMG:style_emoticons/default/dry.gif)
Dr Evil |
Apr 18 2011, 07:01 PM
Zach =
balljoint |
Apr 18 2011, 08:00 PM
You guys are not helping.
Zach, Just blow in the other end. Or. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.3si.org-1897-1303179450.1.jpg) |
messix |
Apr 18 2011, 08:19 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
unthread the hose at the gauge then use a spark plug socket in the hole then a larger socket over that. [some spark plug sockets have a hex nut on the end].
MDG |
Apr 18 2011, 08:43 PM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Razorbobsr |
Apr 19 2011, 07:06 AM
Member Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
I have a compression tester stuck in Cyl 4 (one of the deep ones). the rubber spins, but where it threads in is tight and won't thread out. Any clue as to how to get the darned thing out? Without cutting the rubber to get a pair of needle nose pliers in there? over 160 compression, so at least thats good. :-) (turned out the cylinder was not firing due to a plugged idle jet. Which I had guessed. But I was curious about the compression. Something about killing a cat...) Zach |
Dr Evil |
Apr 19 2011, 07:24 AM
Give this guy a call. He is a whiz with metal and getting it to do what he wants (IMG:style_emoticons/default/wink.gif)
Dr Evil |
Apr 19 2011, 07:32 AM
Sorry, the previous pic was of him out of complete costume. You might have been thinking, "how is Matlock good with metal?" (IMG:style_emoticons/default/confused24.gif)
Here he is, I bet you recognize him now. At the very least, you can stand next to the engine, raise your hand and try to command the piece out. Attached image(s) |
VaccaRabite |
Apr 19 2011, 08:12 PM
Was not able to get into the garage tonight (did not get home till late and its been pouring all day), so I will have to take a better look at it tomorrow.
Zach |
tracks914 |
Apr 19 2011, 08:20 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
My guess, have someone crank the car over while you are trying to twist the hose loose. While the hose is under compression, there might be enough pressure on the joint to hold it to the base while you get it loose. As long as you are twisting during the compression stroke, you have a chance. (Although the threads will be tighter too you might just get it.)
Other than that....cut it. |
Mike Bellis |
Apr 19 2011, 08:49 PM
Pull the head off and you can unscrew it from the combustion chamber (IMG:style_emoticons/default/biggrin.gif)
Dr Evil |
Apr 19 2011, 09:08 PM
Honestly, that is the most sensible approach (IMG:style_emoticons/default/smile.gif) Dont forget to remove the gas tank first!
messix |
Apr 19 2011, 09:20 PM
ASSHATS
jcambo7 |
Apr 19 2011, 09:50 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
sww914 |
Apr 19 2011, 09:58 PM
Come on Zach, I'm anxious for you to resolve this. Don't be a quitter. (IMG:style_emoticons/default/smile.gif)
Is it raining inside your garage? |
VaccaRabite |
Apr 20 2011, 06:35 AM
It's on my hitlist for tonight. Mike's jealous that I have at least the possibility of driving something cool to Hershey. The rest of y'all are just mean.
Zach |
Apr 20 2011, 07:15 AM
you could go to Kmart and buy a deep socket, then drill it out so it fits over the hose...that might do it.
Rich |
tod914 |
If it's spinning from the compressor side, maybe try dropping the motor and turning it instead. In theory, it should work. Good luck Zach. You probally wouldn't want to use it again anyway, maybe snipping it so you can get some needle nose to get in there to grip it might be easiest.
Lo-Fi Version | Time is now: 18th May 2024 - 08:23 PM |
