Do your visors ever fall down?, Too many pics for a simpleton fix |
76-914 |
Apr 18 2011, 10:13 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
This is not where your visor belongs but it is where I threw mine when it would come off:
This is cheap, simple and takes <20mins start to finish. I used a 1/16" bit and drilled thru the outer visor clip with the plastic pin in place. Be sure the pin is pushed completely into the post before drilling. Drill at an upward angle. NOTE: the center post will be drilled at a downward angle and the nail will be pushed in from the front, instead of the back. Here is the nail pushed thru the hole from the back side with the head on the "top" so it will not fall thru. The nail will not slide or work it's way out at this angle. At this point I cut the end off the nail w/ side cutters then remove the nail and file it down enough to fit flush then dip the ends in black paint or use a Marks-a-lot (my favorite). Then re-insert the nail with the plastic pin still in place. Once the nail is in place, slide the visor back onto it's plastic pin. This is actually the psg side and it isn't black, yet. Now take your needle nose pliers and slide the inner visor pin into the center post, When it is seated in the post drill at a downward angle as shown: This is a shot looking up at the center post with one nail clipped and the other full length: When your finished it will never show unless u CC it (IMG:style_emoticons/default/lol-2.gif) In closing; the size of bit doesn't matter as long as it is small and the nail you will be using fits the hole tightly. I picked the nail first and used a bit that was correct for that size nail. I suppose you could use a paper clip piece and a #60 bit if you wanted it to be tiny. Any angle works. The more accute the angle, the more difficult the job. Be sure the plastic pin is seated and that you drill at a halfway point. Since I've done this I no longer over tighten the ever living dog shit out of my visors, hoping that they will stay in place. With the pins properly seated and staked the visors cannot slide off. Now they are just snug enough to operate smoothly. |
Lo-Fi Version | Time is now: 27th May 2024 - 10:38 AM |
