Anyone have pictures of their hole..., ...where the antenna goes? |
Eric_Shea |
May 13 2004, 03:01 PM
Z... we've already seen your hairy ass so you need not post it here. (IMG:style_emoticons/default/bootyshake.gif)
I'm looking for antenna locations for the "Passengers Side" only. Can you post some pictures gang? Thanks! |
skline |
May 13 2004, 03:37 PM
Sure, no problem. Mine is on the passenger side which is where I believe it should be. There was even a grommet there for the antenna cable to go through. ope this helps you. Its a Hirshman power antenna.
Attached thumbnail(s) |
skline |
May 13 2004, 03:41 PM
Here is one a little closer up.
Trekkor |
May 13 2004, 03:55 PM
Here's mine. I want to use a grommet to cover the hole for now until I put in a power ant. after it has a radio (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 13th May 2024 - 08:19 AM |
