Z... we've already seen your hairy ass so you need not post it here.
I'm looking for antenna locations for the "Passengers Side" only. Can you post some pictures gang?
Thanks!
skline
May 13 2004, 03:37 PM
Sure, no problem. Mine is on the passenger side which is where I believe it should be. There was even a grommet there for the antenna cable to go through. ope this helps you. Its a Hirshman power antenna.
skline
May 13 2004, 03:41 PM
Here is one a little closer up.
Trekkor
May 13 2004, 03:55 PM
Here's mine. I want to use a grommet to cover the hole for now until I put in a power ant. after it has a radio
