IT IS ALIVE!!!!, Blond is revived from it's long sleep... |
Red-Beard |
May 13 2004, 10:11 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
The wiring on the MSD needed better connections.
Fired up! Wooooo Hoooooo! Did the 20 minute 4000 rpm breakin. Ran out of time to do a road test. The acellerator linkage needs a little work. It seems that the carbs are lower, or something. And yes, I put the spacers in... Can't wait to break in the rings. James (IMG:style_emoticons/default/MDB2.gif) |
Joe Bob |
May 13 2004, 10:21 PM
Red-Beard |
May 13 2004, 10:32 PM
#1
Red-Beard |
May 13 2004, 10:33 PM
#2
Rusty |
May 14 2004, 03:29 AM
James,
Did you build the 2.7/6 or have a shop do it? (I'm assuming that's the reason for the break-in period... forgive me, I don't get to read all the posts.) -Rusty (IMG:style_emoticons/default/smoke.gif) |
Red-Beard |
May 14 2004, 06:22 AM
I had a local engine builder put the engine together. The assembly charge was only $850, so I had them do the engine complete.
If I just had it re-ringed (Along with the head repairs, valve guides, etc), I would have spent about $2500. It was closer to $6000 with the extra work (Porting), new P&Cs, new crank and rods, installation of piston squirters, and the carb parts to properly handle the 2.7. Hopefully, I can put the sucker on the road next Wednedsay. Going to Houston tonight. (IMG:style_emoticons/default/sad.gif) |
Joe Bob |
May 14 2004, 06:30 AM
Rusty |
May 14 2004, 09:25 AM
QUOTE(Red-Beard @ May 14 2004, 04:22 PM) I had a local engine builder put the engine together. The assembly charge was only $850, so I had them do the engine complete. If I just had it re-ringed (Along with the head repairs, valve guides, etc), I would have spent about $2500. It was closer to $6000 with the extra work (Porting), new P&Cs, new crank and rods, installation of piston squirters, and the carb parts to properly handle the 2.7. I keep dreaming that one day I can build my own /6 motor. Then I wake up. For what it would take to "properly" build my 2.0 (or upgrade it to a nice little 2.2 or 2.4,) I can probably buy a used 2.7+ in good condition. Having the uncontrollable urge to do stuff yourself is often the hard way to do things. Good luck getting it back on the road! We need pics! -Rusty (IMG:style_emoticons/default/smoke.gif) |
J P Stein |
May 14 2004, 11:50 AM
I bought a 2.7L long block for 500 bucks.
Put in another 4K (or so) for 200 (or so ) hp......DIY. Do some research on the motors before you jump. Unlike some of my 914 projects, the engine building was fun. (IMG:style_emoticons/default/biggrin.gif) |
Toast |
May 14 2004, 12:14 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
About time! (IMG:style_emoticons/default/wink.gif) Once everyone gets their cars running and after the WCC, we should schedule another So. Cal run. (IMG:style_emoticons/default/beerchug.gif)
Hopefully being behind you this time, I wont get covered in oil. (IMG:style_emoticons/default/ph34r.gif) Wait a minute, what do I mean I'll be behind you. You'll have to catch me. (IMG:style_emoticons/default/cool.gif) |
MXMARK |
May 14 2004, 12:48 PM
Member Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 |
Red-Breard, good job.
Toast, Yes lets do a So Cal. drive. Thank you Mark |
Red-Beard |
May 14 2004, 03:01 PM
Off to Houston.
"Now you know you're not supposed to drive the Porsche while we're gone..." "Relax, we trust you." (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) James (IMG:style_emoticons/default/burnout.gif) |
MXMARK |
May 14 2004, 03:12 PM
Back in 1986 I took my friends 1974 carrera out for a drive when he was gone. He said it needed an oil change so It should not be driven. Well I was 19 and thought I can change the oil. Boy does that tank hold alot of oil. Everything was easy to work on and went back together easy. I told him what i did when he got back, He was not mad. James don't worry I have three Porsches now so ....... Wait where do you live? Just kidding. Mark
Red-Beard |
May 15 2004, 06:41 AM
Hmmm. We do need to revive Baja III.
It's about time! James (IMG:http://www.pelicanparts.com/support/smileys/wat.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 09:33 PM |
