Distributor Shaft Play, How much is too much? |
Lawrence |
Apr 15 2003, 09:30 AM
I had my distributor out last night, and was checking play, after I wiggled the rotor. I thought maybe I had some wear on the rotor, but the play was coming from the shaft.
How much play is too much, both up/down and left/right? -Rusty |
porsche735 |
Apr 15 2003, 09:59 AM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
Up and down is OK. Left and right is bad. You really shouldn't be able to jiggle it.
Chris |
Bleyseng |
Apr 15 2003, 10:38 AM
It should be tight with no movement side to side. Nice smooth operation but up/down is ok.
Geoff |
Mueller |
Apr 15 2003, 10:52 AM
Hey Rusty......
Throw away the dizzy (IMG:style_emoticons/default/smile.gif) DIY Distributorless Ignition |
need4speed |
Apr 15 2003, 12:44 PM
Member Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
Get a timing light. Run it and watch the strobe on your pully. If the timing mark doesn't sit still (varies by more than 3-5 degrees at any RPM), that's too much play.
airsix |
Apr 15 2003, 04:13 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
QUOTE(need4speed @ Apr 15 2003, 10:44 AM) Get a timing light. Run it and watch the strobe on your pully. If the timing mark doesn't sit still (varies by more than 3-5 degrees at any RPM), that's too much play. My dizzy is pretty loose. Lots of timing wander. I put in a Crane optical pickup to replace the points and it's very steady now. Stays right on the mark all the way to redline. Are we talking about your -4 or your -6 or you 9eleben? -Ben M. |
Lawrence |
Apr 15 2003, 04:22 PM
There is a tiny amount of movement. Can a distributor be rebushed like a throttle body?
-Rusty |
Bleyseng |
Apr 15 2003, 06:20 PM
Of course, that's how they rebuild 'em.
Geoff |
porsche735 |
Apr 21 2003, 12:33 PM
I got mine done at this place:
http://www.philbingroup.com/rebuilt/specia...al_services.htm They did very good work and it was only $60 shipped back to me! Chris |
Lo-Fi Version | Time is now: 19th May 2024 - 09:42 PM |
