I had my distributor out last night, and was checking play, after I wiggled the rotor. I thought maybe I had some wear on the rotor, but the play was coming from the shaft.
How much play is too much, both up/down and left/right?
-Rusty
porsche735
Apr 15 2003, 09:59 AM
Up and down is OK. Left and right is bad. You really shouldn't be able to jiggle it.
Chris
Bleyseng
Apr 15 2003, 10:38 AM
It should be tight with no movement side to side. Nice smooth operation but up/down is ok. Geoff
Get a timing light. Run it and watch the strobe on your pully. If the timing mark doesn't sit still (varies by more than 3-5 degrees at any RPM), that's too much play.
airsix
Apr 15 2003, 04:13 PM
QUOTE(need4speed @ Apr 15 2003, 10:44 AM)
My dizzy is pretty loose. Lots of timing wander. I put in a Crane optical pickup to replace the points and it's very steady now. Stays right on the mark all the way to redline.
Are we talking about your -4 or your -6 or you 9eleben?
-Ben M.
Lawrence
Apr 15 2003, 04:22 PM
There is a tiny amount of movement. Can a distributor be rebushed like a throttle body?
