Rear arm adjust. Torque needed! +dumb bolt problem, can't find in book or search :( |
mskala |
May 15 2004, 05:51 PM
Hey,
I just was taking out shims in back for first time, and I need two answers. I used to know the torque those three bolts go to, I can't find any record of it in the books or search here. Also, I'm down to 2mm of shim on right side, and the bolts 'seem' to bottom out before squeezing the parts together. Could that be because of corrosion from never having bolt up there that far in 30 years? Or do I need to put a few mm of washers on the bolts? Maybe both? I have to get the thing back together. Over a year ago I put in the plastic bushings, didn't have any problem like this although I didn't take any shims out then. Thanks a lot! (IMG:style_emoticons/default/wub.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:55 AM |
