Hydraulic clutch options - V8 and 915 |
ewdysar |
Apr 25 2011, 12:48 AM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Hi guys,
I'm finally getting around to installing my 915 with Wevo sideshift into my Renegade conversion. I'd like to go with a hydraulic clutch setup. Anybody have a comprehensive list of parts? Will the 993 pedal cluster fit in the 914? Anybody use an annular throwout setup, like Wevo has for their racing clutches? Unfortunately, I believe that the Wevo piece doesn't have enough throw for the conversion clutch/pressure plate. Thanks for your help... Eric |
PRS914-6 |
Apr 25 2011, 05:59 AM
Loser_Cruiser |
Apr 25 2011, 12:10 PM
Member Group: Members Posts: 407 Joined: 4-April 05 From: Bellingham, WA Member No.: 3,873 Region Association: Pacific Northwest |
Prs, I totally missed that on your build. Awesome.
RON S. |
Apr 25 2011, 06:06 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Eric,
I have converted/grafted the 964 slave unit to fit the 914 pedal cluster. It was not a difficult adaption, and it has been working nicely on my 914/6 for over 5 years now with no issues or leakage. It has a smooth linear feel to it. Here are some really old pics taken during the conversion. It did require re routing the throttle linkage and having a custom cable made. Which can cheaply be purchased from Pegasus Auto Racing. Good Luck. Ron Attached image(s) |
ewdysar |
Apr 26 2011, 10:02 AM
Thanks for the responses so far. From what I've seen, I'm leaning towards what PRS914-6 did for his setup. I'm still wondering if anyone has put a 993 cluster in a 914 yet.... Eric |
rohar |
Apr 26 2011, 10:29 AM
Senior Member Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
Thanks for the responses so far. From what I've seen, I'm leaning towards what PRS914-6 did for his setup. I'm still wondering if anyone has put a 993 cluster in a 914 yet.... Eric I'm pretty sure the Neo914 used a 993 cluster. Since the master is virtually the same for the 993 and the Audi unit, I've been looking at both solutions pretty close. I'm thinking I'll probably end up with a variant of what PRS914-6 did. |
Andyrew |
Apr 26 2011, 10:31 AM
I think im going to install a master cylinder from a 95 civic. Its $25 new, 3/4" and looks very similar to whats posted above.
http://www.autozone.com/autozone/parts/Dur...ier=541722_0_0_ I might try and make the stock slave cylinder work as well, but that is going to be more difficult. $11... http://www.autozone.com/autozone/parts/Dur...ier=227997_0_0_ If they ever break, they are available at any parts store. |
PRS914-6 |
Apr 26 2011, 11:57 AM
A few things to keep in mind......
1. There is not much room to mount a clutch and brake master cylinder side by side where each one mounts with a flange horizontally. One of the reasons I went with a vertical mount. Check the dimensions prior to purchase. 2. Check the stroke and make sure the cylinder is long enough 3. My slave is a "pull style" meaning when I push on the peddle, the rod RETRACTS. Not much room to mount on the other side on a 915 to use a push style slave. It pulls from the same direction that a cable would. 4. Make sure the slave and master are the same size diameter. Using the same diameter equates to the same movement as a cable would 1:1 |
ewdysar |
Apr 26 2011, 12:54 PM
Thanks for the responses so far. From what I've seen, I'm leaning towards what PRS914-6 did for his setup. I'm still wondering if anyone has put a 993 cluster in a 914 yet.... Eric I'm pretty sure the Neo914 used a 993 cluster. Since the master is virtually the same for the 993 and the Audi unit, I've been looking at both solutions pretty close. I'm thinking I'll probably end up with a variant of what PRS914-6 did. So after reading lots of the Neo914 threads, I believe that answer is that the 993 cluster will not work in the 914 (at least Neo didn't make it work). The 964 cylinder can be grafted into the cluster, but it lives inside the cabin. I'm still headed towards the PRS914-6 solution... |
rohar |
Apr 26 2011, 02:06 PM
It's been too long since I read those threads. My apologies for being a bit off. I'm gonna attempt something similar with an audi master (same geometry as the later P car cyls) shortly. My biggest concern is getting the throw on the bellcrank right as I'm trying to hook up to a stock audi tranny. We'll see as soon as I'm done with the motor mounts...
Lo-Fi Version | Time is now: 18th May 2024 - 03:16 PM |
