weber carbs, altitude |
914 shifter |
Apr 25 2011, 01:41 PM
airhead Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
new car has dual weber 40 idf. the area the car came from is 1600 ft in altitude
i am at or close to sea level. car runs well and i am in the process of educating myself on the webers. specific jets for sea level ? etc. |
Apr 25 2011, 01:51 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
new car has dual weber 40 idf. the area the car came from is 1600 ft in altitude i am at or close to sea level. car runs well and i am in the process of educating myself on the webers. specific jets for sea level ? etc. If they were jetted for 1600ft you might want to up the jet size as it would be running a bit lean at sea level. Find someone with a exhaust sniffer or read the plugs to see if you are indeed running too lean. (IMG:style_emoticons/default/bye1.gif) |
Apr 25 2011, 02:04 PM
What do you have for Jets now?
I have found a simple way to do this. Call Aircooled.net... They have a spreadsheet that has known good setups for specific locations and altitudes. You need to know your engine size...that is about it. They sell all the jets and venturis and emulsion tubes...so they make suggestions that work for you...or they will swap them out until you are happy... Good group to work with on this topic. Rich |
AndyB |
Apr 26 2011, 03:52 PM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
Did you get the answer you were looking for?
Lo-Fi Version | Time is now: 18th May 2024 - 04:50 PM |
