Gary |
Senior Member ![]() ![]() ![]() Group: Members Posts: 748 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region ![]() ![]() |
Hi Brad,
Thanks for starting this forum. There was a thread a while back on the PP forum about using 911 axles and stubs on the 914. Did you ever get a chance to check the year on the 911 axles that fit? My axles apparently have given up the ghost, so I'm looking for the right ones. Right now I'm running the early 911 stubs with 914 axles and adapters for the stubs. Pelican lists two flavors of early 911 axles: 65-68 or 69-73. The 65-68 are the Lobro CVs, but you thought maybe the later ones? TIA, Gary |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Gary,
it is the later 69-73 axles. You will need the 69-73 901 output flanges for the tranny also. I really need to get pics of this for everybody. B |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
Write a tech-article for the site while you're at it (IMG:style_emoticons/default/biggrin.gif)
Cheers, Jeroen |
914Timo |
******* ![]() ![]() ![]() Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe ![]() |
Yes, write a tech-article Brad. (IMG:style_emoticons/default/clap56.gif)
VW bus axles are 475 mm long. I think 914 axles are 500 mm long from end to end. Timo |
Jeroen |
hey timo,
welcome a board! cheers, Jeroen |
Brad Roberts |
Let me put that on my list of things to do.
I know it needs to be done (badly) I'm almost caught up with last years list. B |
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,107 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
I am also in the process of doing this.
What is the output flange is that the drive shaft that is on the outer end of the cv that attaches to the hub? Also where can you buy CV joints that arent so expensive? |
echocanyons |
Alright I got it output flange on the trans.
echocanyons |
I cannot recall but was it determined that a spacer was needed to make up for the shorter 911 axels?
Brad Roberts |
We have raced the cars for years without the spacers. The CV's are larger and therefore have more "play" in them than the narrower 914 and BUS CV's.
The can handle for angle. B |
echocanyons |
is this the output flange?
echocanyons |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
That is in fact a transaxle output flange.
echocanyons |
This is a 911 flange so whats the difference between the 914 flanges?
I assume its the CV bolt pattern |
Brad Roberts |
The 914 is tiny compared to that one. The one pictured is the same size as the 930 Turbo output flange. The only difference is 6 bolts and no pins for the 930. The early 911 CV that fits that is EXACTLY the same CV as the 930 Turbo (except it uses 4 bolts and 2 pins.
NOW: I have found out (the hard way) Porsche had 2 different output flanges for the 911/901 box. One is slightly longer than the other. The one pictured slips right into all 914/901's including the limited slip diff. No shit.. I pulled these flanges today to get pics for you guys... you saved me the time. I'll see if I can show you the stub axle (later today) B |
echocanyons |
Would these output flanges fit a 915 as well or are they totally different?
Brad Roberts |
They dont even resemble the 915 output flanges. Nor do the stub axles.
B |
Lo-Fi Version | Time is now: 11th July 2025 - 01:59 AM |
