high idle question |
Apr 15 2003, 09:15 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
D-jet
Idles around 1700 when hot.... replace it all already, except the Aux air valve... that is blocked off, but I am suspicious of it leaking, possibly adding more air into the intake when hot.... Not sure. Help Rich |
Bleyseng |
Apr 15 2003, 09:40 PM
1. Vacuum leaks from whatever. Test spray around the hoses, injectors, plenum, throttle body with alittle bit of starting fluid to see if the rpms go up. Note: I said alittle. Too much spray will mix with all the air in the engine compartment and into the intake, result: the idle will rise. Also beware of the fire danger.
2. The timing is way off 3. The vacuum retard hose isn't connected properly Geoff |
Lo-Fi Version | Time is now: 20th May 2024 - 12:42 AM |
