r_towle
Apr 15 2003, 09:15 PM
D-jet
Idles around 1700 when hot....
replace it all already, except the Aux air valve...
that is blocked off, but I am suspicious of it leaking, possibly adding more air into the intake when hot....
Not sure.
Help
Rich
Bleyseng
Apr 15 2003, 09:40 PM
1. Vacuum leaks from whatever. Test spray around the hoses, injectors, plenum, throttle body with alittle bit of starting fluid to see if the rpms go up. Note: I said alittle. Too much spray will mix with all the air in the engine compartment and into the intake, result: the idle will rise. Also beware of the fire danger.
2. The timing is way off
3. The vacuum retard hose isn't connected properly
Geoff
