Towbar adaptor, Using a VW towbar on a 914 |
John Kelly |
May 21 2004, 01:32 PM
Senior Member Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
I'm sure this has been done before...see attached picture for my version, or look at the album for a few more pictures and information. No, I do not want to go into business making these!
http://allshops.org/cgi-bin/community/comm...d=9980160442904 John www.ghiaspecialties.com Attached image(s) |
tat2dphreak |
May 21 2004, 01:38 PM
cool deal man!
I think James Adams has his own tow bar adapter too... a little different from this. thanks for the info! |
lmcchesney |
May 21 2004, 02:52 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
Finally an after market product which will give our 914' those really quick 0-60 times.
Nice John. (IMG:style_emoticons/default/welder.gif) |
STL914 |
May 21 2004, 07:03 PM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
John, how is the tow bar adapter secured in the trunk?
John Kelly |
May 22 2004, 09:26 AM
Hi Gary,
There is a crossbar bolted between the bumper bracket mounts that everything is welded to. It uses the front two bolts on either side. I was going to have a brace run under the car for more stiffness, but it turns out to be stiff enough as is. Have not road tested it yet...will be using a safety chain as always, just in case. L. McChesney, I'm thinkin' if all works out, this 914 won't have much of a problem going a lot faster than my truck...probably about 60 mph faster than I ever want to go...Roland went 140 easy with this engine in his 914...erf! John www.ghiaspecialties.com |
Lo-Fi Version | Time is now: 22nd May 2024 - 06:28 PM |
