carb guru needed |
carb guru needed |
ruddyboys |
May 21 2004, 04:03 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I have dual webber 40 IDF, the carb was leaking through the accelerator pump diaphragm. After replacing it the carb over flows throug the top? I checked the needle valve and it moves freely and is attached to the floats. The floats also move freely. Could it be the floats need to be adjusted, if so how. (IMG:style_emoticons/default/pissoff.gif)
Lo-Fi Version | Time is now: 15th May 2024 - 01:36 PM |
