Dual Master Cylinder Setup, Finally complete |
ChrisFoley |
May 21 2004, 04:25 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I finally got everything bolted up and ready to add fluid.
These are Tilton M/C's and brake pedal with a heavily modified Tilton mounting bracket. The red hose is a bias adjuster with a knob in the cockpit. There is a microswitch up front for the brake lights. Attached image(s) |
ChrisFoley |
May 21 2004, 04:26 PM
Here's what the pedals look like.
Mueller |
nice install......are you running "huge" calipers now or just needed the adjustibility of this setup??
ChrisFoley |
May 21 2004, 04:27 PM
I had to make shortened actuator rods to fit things in the space available. The long one came with the M/C.
Mueller |
think it'll take a while to get used to having the pedals on different pivot points?
tat2dphreak |
May 21 2004, 04:29 PM
DUDE! that looks sweet!
ChrisFoley |
May 21 2004, 04:30 PM
QUOTE(Mueller @ May 21 2004, 06:26 PM) nice install......are you running "huge" calipers now or just needed the adjustibility of this setup?? Vented rotors with M calipers up front and modified stock rear calipers. Working within SCCA limitations. I wanted more flexibility than the stock M/C setup provides. |
ChrisFoley |
May 21 2004, 04:32 PM
QUOTE(Mueller @ May 21 2004, 06:27 PM) think it'll take a while to get used to having the pedals on different pivot points? I bet it will feel strange at first. But I'll be used to it after one race. (IMG:style_emoticons/default/biggrin.gif) |
ss6 |
May 21 2004, 04:35 PM
fun city... Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 |
You make it look so easy. (IMG:style_emoticons/default/smilie_pokal.gif)
Kinda close to the go-pedal, though, or is it the angle the pic was taken from? |
ChrisFoley |
May 21 2004, 04:40 PM
QUOTE(ss6 @ May 21 2004, 06:35 PM) Kinda close to the go-pedal, though, or is it the angle the pic was taken from? The picture angle makes it look too close, but it's just about right for heel and toe braking/downshifting. |
skline |
May 21 2004, 07:01 PM
I am impressed..........and not worthy (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif)
Jeroen |
May 21 2004, 07:10 PM
Nice job Chris!
I found this recently... tempting (IMG:style_emoticons/default/wub.gif) cheers, Jeroen Attached image(s) |
tat2dphreak |
May 21 2004, 07:16 PM
QUOTE(Jeroen @ May 21 2004, 07:10 PM) Nice job Chris! I found this recently... tempting (IMG:style_emoticons/default/wub.gif) cheers, Jeroen OMG!!! I think I'm in lust! how $$ will that kill my wallet? |
skline |
May 21 2004, 07:24 PM
Yeah that is sweet, I wonder where you would find something like that?
ChrisFoley |
May 21 2004, 08:01 PM
QUOTE(Jeroen @ May 21 2004, 09:10 PM) I found this recently... tempting I actually started down a similar path, but realized that adjustments and maintenance were too much of a hassle with the m/c's down there. I was 75% done even and changed my mind. You can see the 2 holes for the dual m/c's in this pic. I bled the system tonight and am a disappointed by a little flex in the sheet metal. Apparently the reinforcement I made wasn't enough. The pedal does feel nice and firm, so otherwise I like it so far. (IMG:style_emoticons/default/smile.gif) One more thing, I installed Earl's "solo-bleed" bleed screws, but had to remove them. It is impossible to fill a dry system with them in place. They might work fine on a system that is already bled once. Attached image(s) |
lapuwali |
May 21 2004, 08:52 PM
What's interesting about Jeroen's pic is that it doesn't look like the M/Cs go through the sheet metal. It looks like that blue thing on the end is the fitting for the brake hose. Both M/Cs are entirely inside the footwell. Hm. Where is that pic from, and are there any other details?
Jeroen |
May 21 2004, 09:09 PM
The pedal box shown is a modified stock box (although this is a later one, mounted in an early 911)
Brackets for the M/C were added and a provision for the balance bar on the brake pedal All is inboard mounted... I contacted the owner. He was planning to make more of these to sell, but he doesn't have the time at the moment <_< cheers, Jeroen |
URY914 |
May 22 2004, 05:53 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,693 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Once again Chris, you've done a nice job.
Paul |
Part Pricer |
May 22 2004, 06:52 AM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
I had to put the two of these together. I got tired of scrolling up and down to compare them.
(IMG:http://www.914world.com/bbs2/uploads/post-2-1085178310.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-2-1085188235.jpg) |
Lo-Fi Version | Time is now: 19th May 2024 - 01:26 AM |
