QUOTE(Jeroen @ May 21 2004, 09:10 PM)
I found this recently... tempting
I actually started down a similar path, but realized that adjustments and maintenance were too much of a hassle with the m/c's down there. I was 75% done even and changed my mind. You can see the 2 holes for the dual m/c's in this pic.
I bled the system tonight and am a disappointed by a little flex in the sheet metal. Apparently the reinforcement I made wasn't enough. The pedal does feel nice and firm, so otherwise I like it so far.
One more thing, I installed Earl's "solo-bleed" bleed screws, but had to remove them. It is impossible to fill a dry system with them in place. They might work fine on a system that is already bled once.
