oil pressure gauge, are these the right parts? |
rwilner |
May 1 2011, 01:30 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Mike Bellis |
May 1 2011, 03:54 PM
Did you read the description of the sender?
"We don't feel that the VDO 80psi Oil Pressure, 1/8-27 NPTF, Dual Pole Sending Unit is the "right" sender to use for aircooled VW Engines because the oil light comes on at too high a pressure. Stock is 2psi, this comes on at 7-8psi." Sounds like it will work electrically but your light will be on at any pressure less than 7psi. |
rwilner |
May 1 2011, 04:32 PM
Did you read the description of the sender? "We don't feel that the VDO 80psi Oil Pressure, 1/8-27 NPTF, Dual Pole Sending Unit is the "right" sender to use for aircooled VW Engines because the oil light comes on at too high a pressure. Stock is 2psi, this comes on at 7-8psi." Sounds like it will work electrically but your light will be on at any pressure less than 7psi. I figure that's ok since the only time it'll be @ 7psi is at idle. |
914Sixer |
May 1 2011, 04:51 PM
914 Guru Group: Members Posts: 8,896 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I am selling a custom gauge(N Hollywood) that is factory 60mm console size and sending unit in the classified section for $120.
Cevan |
May 1 2011, 04:52 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I used a braided hose from a paint ball store. Use some hightemp thread sealant on the threads.
Lo-Fi Version | Time is now: 29th May 2024 - 09:15 PM |
