Also, will a stainless braided brake line work to connect the sender to the sensing port on the block?
Thanks Rich
Mike Bellis
May 1 2011, 03:54 PM
Did you read the description of the sender?
"We don't feel that the VDO 80psi Oil Pressure, 1/8-27 NPTF, Dual Pole Sending Unit is the "right" sender to use for aircooled VW Engines because the oil light comes on at too high a pressure. Stock is 2psi, this comes on at 7-8psi."
Sounds like it will work electrically but your light will be on at any pressure less than 7psi.
rwilner
May 1 2011, 04:32 PM
QUOTE(kg6dxn @ May 1 2011, 05:54 PM)
I figure that's ok since the only time it'll be @ 7psi is at idle.
914Sixer
May 1 2011, 04:51 PM
I am selling a custom gauge(N Hollywood) that is factory 60mm console size and sending unit in the classified section for $120.
Cevan
May 1 2011, 04:52 PM
I used a braided hose from a paint ball store. Use some hightemp thread sealant on the threads.
