See If you can tell where these rubber pieces go, Most are missing on engines |
914Sixer |
May 1 2011, 04:46 PM
914 Guru Group: Members Posts: 8,885 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I thought I might have some fun with these. Like I said most of theses are missing on most engines. Both are NLA and I am not sure if they have been reproduced yet.
Cevan |
May 1 2011, 05:00 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
The one on the right goes thru the thermostat cable where it exists the engine tin. I think AA has it.
The one on the left could be throttle cable grommet. |
type47 |
May 1 2011, 05:01 PM
Well, the one on the right looks like the thermostat cable grommet for where the cable runs through the tin above the alternator.
I hope I beat Cevan on the other one. I think it's the grommet for the telethermometer sender aka Taco plate oil temperature sender. It's the grommet for the wire through the cover plate. |
914Sixer |
May 1 2011, 05:29 PM
Well it look like it wasn't as hard as I thought it might be. Jim is correct on both counts. The grommet is also used somewhere else other than the engine, see if you can guess where.
IronHillRestorations |
May 1 2011, 06:50 PM
Alternator harness grommet?
May 1 2011, 06:58 PM
Holding some trim on? Like the engine grille letters?
--DD |
type47 |
May 1 2011, 07:14 PM
request hint for the other application. Is it used as a wire grommet also in the other application?
JFJ914 |
May 1 2011, 07:31 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
The one on the left is the sealing grommet for the oil temp sensor on the taco plate cover.
jk76.914 |
May 1 2011, 07:42 PM
(IMG:style_emoticons/default/agree.gif) Oil temp sensor wire, exiting taco plate.
914Sixer |
May 2 2011, 07:22 PM
The other place the grommet is used is for the rear factory foglight bracket wire. The light was used on some USA cars.
Eric_Shea |
May 2 2011, 08:37 PM
QUOTE The other place the grommet is used is for the rear factory foglight bracket wire. I'll take one of those too... (IMG:style_emoticons/default/biggrin.gif) |
type47 |
May 4 2011, 06:39 AM
Any clue what the part number is on the taco wire grommet? It's not in the PET diagrams, just the taco parts and the fog light is not in the PET either.
Upon further search, maybe it's in the fog light listing: PET 905-05 #34 E999.702.011.50 rubber sleeve ??? |
914Sixer |
May 4 2011, 07:16 PM
Part number is 311.949.149A for the boot. The listing Jim (type 47) shows in the PET is a universal type seal. AA is supposed to have reproduce this boot.
Lo-Fi Version | Time is now: 19th May 2024 - 06:12 PM |
