Rear Control Arm Question |
76-914 |
May 1 2011, 09:30 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,503 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm doing rear bearings and one hub with a stripped lug hole. If I remove the shock from the control arm will the arm drop down a few inchs? I need to remove the left drive shaft and even with the starter out I still need a few more inchs to clear.
Mike Bellis |
May 1 2011, 09:32 PM
Yes
Spoke |
May 2 2011, 05:51 AM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I've found it easier to remove the trailing arm from the car to work on the hub.
Lo-Fi Version | Time is now: 19th May 2024 - 11:43 AM |
