76-914
May 1 2011, 09:30 PM
I'm doing rear bearings and one hub with a stripped lug hole. If I remove the shock from the control arm will the arm drop down a few inchs? I need to remove the left drive shaft and even with the starter out I still need a few more inchs to clear.
Spoke
May 2 2011, 05:51 AM
I've found it easier to remove the trailing arm from the car to work on the hub.
