Jukka's 914-6 |
Jukka's 914-6 |
OmaPossu |
May 2 2011, 12:29 AM
Member Group: Members Posts: 241 Joined: 4-October 09 From: Finland Member No.: 10,886 Region Association: Scandinavia |
Hello,
This is a thread about late hours in my garage trying to get 1970 914-6 back to life. There are already hundreds pics in here: http://www.harrasteet.1g.fi/kuvat/OmaPossu+II/ One question, what are these holes for? Spot welding? http://www.harrasteet.1g.fi/kuvat/OmaPossu...+1.5.11+009.JPG |
Dave_Darling |
Jan 28 2012, 11:33 PM
Easier, yes. Cheaper? Not sure.
To change from the tail-shift to the side-shift setup, you not only need to change the transmission (or modify the tail-shift one), but you also need a complete later gear-shift linkage, including all of the rods and even the gear shift lever itself, plus the motor mount bar and all of the mounting hardware for that bar. --DD |
Jeffs9146 |
Jan 28 2012, 11:36 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Easier, yes. Cheaper? Not sure. To change from the tail-shift to the side-shift setup, you not only need to change the transmission (or modify the tail-shift one), but you also need a complete later gear-shift linkage, including all of the rods and even the gear shift lever itself, plus the motor mount bar and all of the mounting hardware for that bar. --DD (IMG:style_emoticons/default/agree.gif) Except he has a factory 6 so the Motor Mount is not an issue! |
OmaPossu |
Jan 29 2012, 02:30 AM
Easier, yes. Cheaper? Not sure. To change from the tail-shift to the side-shift setup, you not only need to change the transmission (or modify the tail-shift one), but you also need a complete later gear-shift linkage, including all of the rods and even the gear shift lever itself, plus the motor mount bar and all of the mounting hardware for that bar. --DD (IMG:style_emoticons/default/agree.gif) Except he has a factory 6 so the Motor Mount is not an issue! Jeff, I wrote about my ex 914 (1971 1,7), not 6. |
Lo-Fi Version | Time is now: 16th May 2024 - 03:40 PM |
