Door switch removal, How do you get them out? |
Cool914 |
May 3 2011, 10:39 AM
Member Group: Members Posts: 98 Joined: 25-January 11 From: Ontario Member No.: 12,627 Region Association: Canada |
Hi,
Trying to pull the wiring harness and can't figure out how to get at the wire on the door switch. I unscrewed the switch and tried to pull if forward but seems like the wire connections hang it up. Pushing the switch into the pillar and out through the hold in the footwell, no doesn't seem to push through. Yanking the wires off the spades, probably could do it but wondering how I would ever get them on again since you can't get your hand in that cavity. I did a search but couldn't find anything but I am sure tons have done it. Help! Also, while I am at it, can you remove the entire dash without having the glass out? Thanks |
Lo-Fi Version | Time is now: 19th May 2024 - 11:41 AM |
