Rotisserie option, How to attach to 75-76 rear |
ldsgeek |
May 3 2011, 06:09 PM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
I am starting to build my rotisserie and have run into a small problem with attaching it to my 1974. It seems that at some point the rear of the car was replaced with a 75-76 version, rubber bumper and all (IMG:style_emoticons/default/mad.gif) . I know how to do the front, bolt on where the bumper goes. Has anyone done a late model rear? How did you attach it? Alternately, where would I drill the holes for a metal rear bumper, as I want to install one anyway? And would I need to reinforce for the rear bumper mount?
Thanks, David T. |
VaccaRabite |
May 3 2011, 09:28 PM
En Garde! Group: Admin Posts: 13,455 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I did it. DEAD easy.
Bolt it right on to the bumper shocks. Boom. Done. I did the front the exact same way I did the back. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.static.flickr.com-1435-1304479728.1.jpg) Zach |
ldsgeek |
May 4 2011, 08:25 AM
I did it. DEAD easy. Bolt it right on to the bumper shocks. Boom. Done. I did the front the exact same way I did the back. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.static.flickr.com-1435-1304479728.1.jpg) Zach Thanks, I wasn't sure if they were strong enough. If it worked for you it should work for me. After fixing the rust I am going to try to locate a steel or fiberglass rear bumper and paint it black to match the front so the shocks will go away at that point. |
Lo-Fi Version | Time is now: 30th May 2024 - 03:23 PM |
