Let the Blasting Begin!, Mobile soda blaster at Series 9 today. |
d914 |
May 5 2011, 07:04 AM
Don't you need to paint something on like right away to keep it from forming rust? No actually soda inparts a rust protection and part of the reason you need to do an acid wash aferward. I had mine in the basement garage for a good year in bare metal.. Major life interfering with the fun stuff.. I only had minor flash rust and that was mostly where I touched the car. Now fla might be a tad worst on the humity front but there should be no need to rush to a primer. |
Series9 |
May 5 2011, 09:36 AM
Don't you need to paint something on like right away to keep it from forming rust? No actually soda inparts a rust protection and part of the reason you need to do an acid wash aferward. I had mine in the basement garage for a good year in bare metal.. Major life interfering with the fun stuff.. I only had minor flash rust and that was mostly where I touched the car. Now fla might be a tad worst on the humity front but there should be no need to rush to a primer. The decks and doors are already gone to the painter for epoxy primer. The blaster said the same as above. The soda residue will protect bare metal for a while. The chassis will be bare for about six weeks. |
Madswede |
May 5 2011, 09:37 AM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
Thats not the one you just put a motor in is it?...... Looks great. Did he bring the rotisserie with him? Since Joe's busy, I'll answer these two Q's. The "other" 3.2L motor is going in James Ellisor's car that Joe's finishing up. http://www.914world.com/bbs2/index.php?sho...ies9&st=140 This one is mine (a longer term complete rebuild project to be completed March 2012). http://www.914world.com/bbs2/index.php?sho...c=113270&hl The rotisserie is Joe's - I believe he made it himself. - Nelson |
AZ914 |
May 5 2011, 12:57 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
This one is mine (a longer term complete rebuild project to be completed March 2012). http://www.914world.com/bbs2/index.php?sho...c=113270&hl Just in time for the Route 66! |
Madswede |
May 5 2011, 04:01 PM
This one is mine (a longer term complete rebuild project to be completed March 2012). http://www.914world.com/bbs2/index.php?sho...c=113270&hl Just in time for the Route 66! Yeah! Only been to one so far, but had fun. Isn't that the event with the "Best Malaga Red 2.0" category? (IMG:style_emoticons/default/poke.gif) |
Elliot Cannon |
May 5 2011, 04:48 PM
Don't you need to paint something on like right away to keep it from forming rust? No actually soda inparts a rust protection and part of the reason you need to do an acid wash aferward. I had mine in the basement garage for a good year in bare metal.. Major life interfering with the fun stuff.. I only had minor flash rust and that was mostly where I touched the car. Now fla might be a tad worst on the humity front but there should be no need to rush to a primer. The decks and doors are already gone to the painter for epoxy primer. The blaster said the same as above. The soda residue will protect bare metal for a while. The chassis will be bare for about six weeks. But then the soda residue hased to be cleaned off before shooting right? If so, what is used to clean it? |
ellisor3 |
May 5 2011, 06:13 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
Thats not the one you just put a motor in is it?...... Looks great. Did he bring the rotisserie with him? Since Joe's busy, I'll answer these two Q's. The "other" 3.2L motor is going in James Ellisor's car that Joe's finishing up. http://www.914world.com/bbs2/index.php?sho...ies9&st=140 This one is mine (a longer term complete rebuild project to be completed March 2012). http://www.914world.com/bbs2/index.php?sho...c=113270&hl The rotisserie is Joe's - I believe he made it himself. - Nelson Your car looks great Nelson. With all the body work I ended doing on mine, I wish I had just had it blasted. I may beat you to the finish line but I started 3 years ago. Seems Joe is right on schedule for March. I can't wait to see yours finished. |
VaccaRabite |
May 5 2011, 06:49 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
To clean the soda resedue use either hot soapy water or vinegar.
Zach |
Rob-O |
May 5 2011, 08:32 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Just a comment on the acid dipping. Works well, but you would really want to cut the outer longs off so you can pull the foil/plastic/cardboard heater tubes off. Which means you'd need to build yourself some supports to keep the dimensions intact.
Personally I'd rather go the soda blasting route! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 09:11 AM |
