TB sticking, What should I do?, Found my high idle problem.. |
Andyrew |
May 26 2004, 10:15 PM
Well today i figured out why my car has such a high idle, the throttle body sticks. So if I manually apply pressure to close it with my hand, it idles fine (well I need to tune the idle screws and mixture but still). So that portrays the question.
What would cause the throttle body to stick? I check the TB plate, and unscrewed it and tryed to fit it better, then tightened it down, didnt help. I set the MPS or whatever that thing is called on the TB.. Now im stuck. I can drive the car, but I still want to figure out this problem. Any idea's? Andrew |
John |
May 26 2004, 10:27 PM
QUOTE Well today i figured out why my car has such a high idle, the throttle body sticks. So if I manually apply pressure to close it with my hand, it idles fine You do mean the throttle valve? D-Jet or L-Jet? QUOTE I set the MPS or whatever that thing is called on the TB.. You mean the Throttle Position Sensor (TPS)? There used to be a guy that rebuilt throttle valves on 914's. I believe you sent him your valve and he would put new bushings in it for the shaft and make it work like new. I think his name was Mike Cooley and the company was Southern Knight Machining. I never sent a valve to him so I don't know the quality of his work, but it may be worth a look. I think he charged something like $43.00 to do it. |
Andyrew |
May 26 2004, 10:32 PM
76 2.0. so D-jet (right?)
I'll just do whatever work myself. Not keeping the engine that long.. lol. Gona blow up some day. |
John |
May 26 2004, 10:45 PM
Well in any event, I dug up the link:
http://www.tolisgroup.com/porsche/mike-ad.html It does show some cleaned up throttle valves. |
MattR |
May 27 2004, 12:03 AM
QUOTE(Andyrew @ May 26 2004, 08:15 PM) ...Any idea's?... EJ20T (IMG:style_emoticons/default/biggrin.gif) |
Rusty |
May 27 2004, 07:26 AM
QUOTE(JOHNMAN @ May 27 2004, 08:45 AM) Well in any event, I dug up the link: http://www.tolisgroup.com/porsche/mike-ad.html It does show some cleaned up throttle valves. Mike Cooley still hangs out on the Rennlist. He joined the 914 Club recently, but I don't see him post much. I don't think he does these TB overhauls anymore. I know that people that received his work were very pleased with the quality. |
Lo-Fi Version | Time is now: 25th May 2024 - 01:27 PM |
